GE8 K24z3 Swap
Old Mar 4, 2020 | 01:38 AM
NicoG's Avatar
GE8 K24z3 Swap
Hi guys! So I know there are a lot of forums regarding how to swap or even general help to swap the fit, but I couldn’t find anything newer. Is nobody interested in swapping the fit anymore? Lol. Anyways I was hoping to get a little more help for my swap regarding wiring, fitment, and all that. I am kind of new to all of this, i am 19 years old trying to do my very first swap. Some info for what I have currently is listed below:
- K24z3 from a 2010 TSX
-2015 Civic Si tranny
- Hasport motor mounts
​​​​​​- Shifter and cables from the Si
- Wiring harness and ecu off the Si, (I believe i need to use the older model harness and ecu off the tsx I believe as it is scary close to the fit wiring?)
- Other misc. stuff like comp clutch injectors etc.
I saw Paul Bomers explanation video on youtube but I didnt really get much out of it, plus he hasn’t updated in months lol. Im trying to figure out the whole wiring issue out so i can safely send it to get it swapped. Any help would most certainly help.
Old Mar 8, 2020 | 09:53 PM
cutsheal5's Avatar
I believe the k
K24Z7 with Z7 was ECU and A2-Z1 or Z3 tranny is the easiest and most direct K swap for the GE8. That engine shares similar sensors and ECU to the GE8 there is a guy on Instagram who’s done it quite simply I believe.
Old Mar 8, 2020 | 11:42 PM
Red 05's Avatar
If I ever go that route I'd pull the K20 out of an '06-11 Civic Si, strictly for the sound. Agree the K24 is a stronger engine overall but I've never heard a K24 sound as great as a stock K20.
It's just me, I know I'm in the minority but that'd be my engine of choice. Would throw a couple bolt-ons at it to hit ~9000k RPM.
Old Mar 9, 2020 | 12:06 AM
cutsheal5's Avatar
It’s not about being stronger the K24Z7 has a compatible ECU and sensor set up that will allow the car to run like normal with the least amount of screwing around.
Old Mar 9, 2020 | 02:11 AM
Red 05's Avatar
Still wouldn't care, it'd be all about the sound. That's worth the headache for me.
Old Mar 9, 2020 | 01:47 PM
NicoG's Avatar
I believe the k
I went with the z3 because it was the cheaper option and with the tight fit, i also found some headers on ebay that might work with the clearance issue, since It has a single exhaust port. I also found a guy that is going to make my custom harness so that works too.
dznuts
Nov 19, 2019 12:02 PM
cbigc69
Sep 16, 2015 08:43 PM
gdnatty
Sep 2, 2015 06:24 PM
Seryoga1
Nov 23, 2010 03:53 AM
NIGHTHAWKSI
Apr 7, 2009 05:02 PM
