Rust spots in my 10 year old Fit
Old Jun 24, 2020 | 09:02 AM
dll932's Avatar
Originally Posted by TnTkr
They all seem stuff, that can help and are not making things worse.
We can hope. I tend to lean towards something transparent, so I see if the rust comes back.
Old Jun 24, 2020 | 11:22 PM
dll932's Avatar
Here's another idea from that Swedish company:
https://www.solventfreepaint.com/veh...t-proofing.htm
Old Jun 25, 2020 | 03:11 AM
TnTkr's Avatar
Linseed oil penetrates well and prevents rust. That was one benefit of my recipe of using iron oxide linseed oil paint. Pure linseed oil has a drawback of fade away due to water and sun, so the treatment has to be repeated time to time. And you don't need a gallon, just some ounces. It does not need to be organic or sterilized for this purpose.
Old Jun 25, 2020 | 09:48 AM
dll932's Avatar
I am intrigued, I will try to see if I can find out more about this.
Old Jun 27, 2020 | 05:26 PM
dll932's Avatar
Old Sep 9, 2020 | 04:05 PM
dll932's Avatar
Follow up to previous: I got the molding, and after looking at it realized it was meant to attach to the glass while it's out of the car! It has a U channel with adhesive already inside. What I ended up doing was cutting the bottom flange of the U channel off and using trim cement (clear) to attach it.
By the way-I cleaned all the rust out but there was none under the molding. I ended up painting the channel with 2 coats of Rust Bullet Auto and 1 of Rust Bullet White shell before replacing the molding.
Ultrawolf
Dec 24, 2020 03:40 PM
KNPSHIN
Dec 20, 2015 12:41 AM
manxman
25
May 6, 2015 03:57 AM
TekXoID
Mar 29, 2010 10:52 PM
manxman
43
Dec 11, 2008 05:32 AM
