2010 ignition won't turn off
Hey guys, long time lurker, first time caller.
I've got a fun one. Last night when I got home from work, I went to turn my car off, and the key stopped at 1st position. I tried everything; wiggling the steering wheel, turning the car on and off again, driving a little bit and cycling through gears - everything. After an hour of Googling (how many blogs do I need telling me the same five steps?!) I gave up and went to pull the fuse to cut power to the radio so my battery didn't die overnight, and I heard a mechanical click from the ignition. The key turned the rest of the way and came out. I replaced the fuse, went to bed, and tried again this morning when I got to work and I had the same issue. I work at an auto parts place, so I grabbed a fuse and replaced it, and the problem persists. It's only removing the fuse for the radio that gets my key out. Now, I guess I can't phrase the issue and it's resolution properly in Google, because I can't find a dang thing about this anywhere. Ideally I'd like to fix this myself, but if this requires a whole new ignition system, I'm going to have to phone a friend. The place I work is a heavy duty truck parts specialty, so no one here even wants to touch my Fit. Frankly, they'd all love it if I traded it in for an F-150 or something. I don't need the radio, so I can just pull the fuse and forget about it, but I want to at least know what the hell is going on. |
The same fuse for the radio is also for the "key lock." I'm betting that either your key is worn down or you'll end up needing a new ignition assembly. It's one big piece that includes the ignition and steering/key lock.
If you have a second key, I'd start by trying that and hope it works. |
Originally Posted by GAFIT
(Post 1448506)
Well??????
| All times are GMT -4. The time now is 05:06 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
