Air shocks for 2013
Looks like Monroe discontinued rear air shocks for the fit.
Whats the alternative for towing? |
The MA809s, but requires a small hub spacer for the air fitting to clear the tire.I did an entire writeup for my GK, but it will be a similar install for the 2nd gen
Originally Posted by Bassguitarist1985
(Post 1452276)
any idea what max tongue weight with orig shocks/springs? |
Its on my 2017 thread. 200lbs max tongue weight for the class I hitch
Fit towing
(Post 1452367)
Same limits apply. Air shocks simply help carry the load better.
(Post 1452404)
air shocks do not increase capacity, just helps carry the load better as in the springs not riding on the bump stops. If they were without air shocks, your tongue weight is too heavy.
(Post 1452434)
your saying tongue wt max is 200# with or without air shocks. But without air shocks springs will be on bump stops.. I think max tongue weight without air shocks is an amount where the springs aren't near the bump stops. Which would be below 200#. |
Originally Posted by over40pirate
(Post 1452436)
not sure why I'm having trouble with this!
your saying tongue wt max is 200# with or without air shocks. But without air shocks springs will be on bump stops.. I think max tongue weight without air shocks is an amount where the springs aren't near the bump stops. Which would be below 200#. Yes max 200lbs tongue weight. Car can only handle a class I hitch. Not saying 200 pounds will weigh the rear to the bump stops, but it will be close. You need air shocks to compensate for that. Either air shocks or air bags inside the springs will do the job. While air shocks/bags are not required, they are highly recommended! |
