No acceleration and p0303 code
Old Feb 10, 2022 | 03:55 PM
tbearfit's Avatar
Originally Posted by Pyts
@tbearfit How'd you settle on the MAF?
Didn't make sense what was going on. Did the carb cleaner spray test and no obvious vacuum leaks (plus the Honda tech originally said he didn't see any either). It was either get a smoke machine or pay the $50 from Rockauto for a new Hitachi sensor.
Old Feb 11, 2022 | 09:47 PM
cutsheal5's Avatar
Originally Posted by beezle
Just adding this - I had a similar issue a couple years ago - very little power, basically couldn't go more than 35-40 mph on flat and 10mph if lucky up a hill. Honda dealer originally diagnosed as fuel injectors and replaced all. Called just before I left to pick up to say 'whoops, that didn't fix it'. They screwed around some more and it ended up being the PCM which had to be replaced. Very lucky for me was still 3 months left on my power train coverage. They ended up not charging for the fuel injectors but I did pay like a $200 (mis)diagnosis charge.
generally on these cars when an injector goes it shorts out the power mosfet driver for that injector and the ecu would need to be replaced along with the injector. I have ran into this multiple times, I can now repair the ecu’s by replacing the power mosfets inside the ecu. If the ecu is not repaired when the injectors are replaced the injector WILL fail again. The ecm can easily be tested for this failure I’ve posted about it multiple times.
Old Feb 11, 2022 | 09:53 PM
cutsheal5's Avatar
Power train control module is what they ended up replacing to fix the issue. Been fine (driving wise) since then.
you can find the thread I discussed it in here.
https://www.fitfreak.net/forums/2nd-...ml#post1463531
here is a link to the video of how and where the mosfets are replaced. Any general electrical repair guy can do it.
Old Feb 21, 2022 | 08:44 AM
tbearfit's Avatar
Luckily (knocks on wood) things seem to be fine now.
GlennO511
Feb 25, 2023 07:52 AM
awbooth
Mar 30, 2021 12:18 PM
Nussjohnathan@gmail.com
Nov 23, 2020 09:03 PM
Beriah
Jul 4, 2019 05:50 PM
fitvanman
Jul 16, 2015 09:51 PM
