Unofficial Honda FIT Forums
Unofficial Honda FIT Forums (https://www.fitfreak.net/forums/)
-   2nd Generation (GE 08-13) (https://www.fitfreak.net/forums/2nd-generation-ge-08-13/)
-   -   Is my 09 Honda Fit's transmission slipping? (https://www.fitfreak.net/forums/2nd-generation-ge-08-13/105837-my-09-honda-fits-transmission-slipping.html)
Spencerrcr May 21, 2022 09:20 PM
1 Attachment(s)
Attached is the video, jesus christ I can't afford this.. :(
Pyts May 22, 2022 12:55 PM
I can't play it. can yuh put it up on youtube?
also, so far every single tranny issue ive encountered on here was resolved with fluid unless there was an accident or some reason for the tranny to fail.
Slipping can be a fluid issue and likely is. Unless you have a manual, in which case it may be the clutch!
I've also resolved several trans slip issues by replacing fluid with redline brand fluid of the appropriate type. Wouldn't fault someone for wanting to stick with OEM juice though as I'm told these days its made specifically for the transmissions it's used in/has a specific additive package that best promotes longevity.
I switch to redline if that fluid was replaced with more oem juice, the level verified, and then the fault comes back in a couple months. you know. if theres no leaks.
usert_l May 23, 2022 09:17 PM
The right side instrument gauge ... something is illuminated but I can't see clearly from the video. Have you noticed that before?
I wonder if an OBDII scanner can help narrow down the problem. Maybe someone here can chime in on that.
szellmaniac Jun 2, 2022 07:17 PM
I just had transmission issues losing acceleration - not exactly like what you were experiencing, but I got a transmission fluid full flush and that solved the problem. If you haven't had your transmission fluid changed out in a long while, might be worth a try.
dogbite Jun 9, 2022 03:21 PM
That looked like a slip to me. I had something similar a week ago.
I was climbing northbound on I15 toward Cedar City--you climb 1500 feet or so. It didn't want to do the speed limit of 80 and I didnt force it. It would do 70-75 depending on the slope at the time. I was getting some RPM spikes with no change in driving experience. If I let off the gas a touch it would maintain speed and RPM. Otherewise, it's been completely solid.
I've got a fluid change scheduled on Monday, 83OOO miles on it.
Pyts Jun 10, 2022 10:13 AM
@dogbite Based on your description i'd suggest wiping out the throttle body too, just to make sure the plate isn't sticking.
dogbite Jun 10, 2022 02:45 PM
I'll look into it.
© 2026 MH Sub I, LLC dba Internet Brands
