Driver side mirror housing replacement issue
Old Jun 12, 2022 | 01:41 PM
johnblazemclane's Avatar
Replaced the driver side mirror with an aftermarket piece. Everything fits well and works except for the 3 mounting bolts. They are slightly longer than OEM so I can't fit the plastic garnish piece back on properly. Could I just use a hacksaw to cut off the little extra nipple? Or should I use a dremel or something else?
edit: little mini hacksaw did the trick perfectly!
aftermarket unit installed
The part I used it anyone is looking for the same
Old Jun 14, 2022 | 10:45 AM
NWCH's Avatar
Yes. That is fine.
Old Jun 14, 2022 | 02:41 PM
AirborneRATT's Avatar
I have replaced a few mirrors on the Fits in my family. The last one I did had this issue. Dremmel or Hacksaw would have worked but you already got it so there we are.
Old Jun 17, 2022 | 07:40 AM
i know tom's Avatar
Vibration
I replaced my passenger side mirror, with one from rock auto claiming to be oem built. I can tell you at high speeds it vibrates. Not terrible but it's noticeable. How's yours?
Old Jun 17, 2022 | 10:31 AM
The housing itself doesn't but the mirror does. Probably similar to yours, not awful but definitely noticeable.
Old Jun 17, 2022 | 11:05 AM
ANGST's Avatar
I just did a passenger side replacement with a "Sherman Replacement Part Compatible with Honda Fit Passenger Side Mirror Outside Rear View (Partslink Number HO1321246)" from Amazon . Same deal , solid mount to the body , mirror flutters at speed . But it was only $50 shipped .
Old Jun 22, 2022 | 11:31 AM
Well that didn't last long...some asshole side swiped my car and ruined the mirror.
cruiserandmax
Mar 29, 2015 01:54 PM
Amanda Tabary
Feb 22, 2014 02:48 AM
Dan_L
Feb 24, 2013 05:36 PM
estlin
Jun 23, 2010 12:07 PM
