ge8 2010 Honda Fit Sport Manual transmission leak
Old Nov 25, 2023 | 05:56 PM
yovtecjustkickedin's Avatar
Question ge8 2010 Honda Fit Sport Manual transmission leak
Hello Fit Owners,
Hope you are well and getting as much use out of your Fit as I do.
The transmission is leaking where it connects to the engine (underneath car). Car has about 150k miles.
Is there a good cheap solution like adding a "stop leak" liquid to the transmission fluid? What are the drawnbacks to doing this?
About how much can I expect to pay to replace the seal?
Any other work that should be done while this work is being done - such as replace timing belt and/or clutch and/or other?
Thanks in advance for your info.!
Yovtecjustkickedin
Old Nov 28, 2023 | 08:06 PM
SanDan's Avatar
Originally Posted by yovtecjustkickedin
Hello Fit Owners,
Yovtecjustkickedin
I'm not expert, but I believe my fit had some leakage out of the drain hole because I never changed my fluid. I've read reports old oil gets hotter and it will create this leak.
So.. are you sure it's not coming out of the hole/plug?
Zacherydeems
Aug 2, 2019 05:17 PM
staffordfit
Jan 25, 2019 02:11 PM
DonkeyKong
Nov 30, 2010 09:22 PM
RickSlick
Apr 11, 2010 12:49 PM
90crxfreak
Sep 21, 2009 10:40 PM
