Cruise control Problem
My 2010 Honda Fit had problem on the cruise control when press the button It shows up on the dashboard screen, but when I press the SET button to fix the speed it won't activate it like the button doesn't work. And one more thing that I noticed is when I accelerate to 120km/h it beep and shows up on the screen but doesn't work. I don't know what's the problem is and and how to reset it or fix it
Cruise control problem-temp fix
That happened to ours, we put a small rubber washer on the set button and taped it around the steering wheel arm three times to keep it tight. It’s been 10 years and it’s still working.
if its 5spd...the plastic button on the clutch pedal probably broke off
