Aftermarket headlamp replacement assemblies - your experiences please
Old Jan 22, 2025 | 03:35 PM
steijw's Avatar
Looking to replace total headlamp assemblies for '09 base, 5 door, MT. Would like to get your purchase/install/fitment experiences, good or bad, with specific aftermarket companies that supply same. Appreciate your time, TIA.
Old Jan 22, 2025 | 09:39 PM
3FITY's Avatar
I never go with after headlights for the simple fact that the lenses will always shed its clearcoat after a year or so. Your better off buying a used set of OEM headlights that are fogged up and then just clearing them up
Old Jan 22, 2025 | 10:23 PM
steijw's Avatar
Interesting response ... if indeed it is just the clearcoat that is deficient (sheds), then why not apply your own clearcoat formulation to the aftermarkets, all things being equal as regards fit and function? Just my initial thought.
Old Jan 22, 2025 | 11:08 PM
3FITY's Avatar
if you do go aftermarket, it would be wise to seal them before use. Oem headlights haze and shed over a long duration under some intense heat but after market ones will shed sheets of the lense within the first year unattended to. I remember Light Depo was one of the better aftermarket headlights and even they would shed
Old Jan 23, 2025 | 09:32 AM
steijw's Avatar
Thank you Friend - appreciate the input and experience.
Old Jan 23, 2025 | 09:35 AM
steijw's Avatar
Now I must search method of sealing the headlamps after acquisition.
Old Jan 23, 2025 | 01:47 PM
GrE8_Fit's Avatar
I would also recommend water sealing them. Everyone I know that bought 3rd party housings had hazed lenses and condensation after a year.
Old Jan 24, 2025 | 07:42 PM
steijw's Avatar
Ok, thanks - I found some vids on how to seal/water seal, and will plan to do so.
No experiences/recommendations for units from particular vendors, or units to avoid?
Old Jan 24, 2025 | 09:05 PM
Tinknocker's Avatar
I put on the brand Eagle Eyes housings three months ago and they seem fine. Went with them because I used them on my truck and they worked just fine for years.
Old Jan 24, 2025 | 09:21 PM
steijw's Avatar
Thanks for the recommendation - appreciate your time and input!!
Dcon
Feb 14, 2022 11:44 AM
zrkd51
Sep 20, 2015 08:20 PM
TrojanMan
Mar 14, 2009 12:14 AM
bobbob911
Dec 29, 2007 05:54 PM
Lilbigwheelz
Apr 6, 2007 03:30 PM
