Can you use a motor from a automatic car
Old Oct 29, 2025 | 11:10 AM
GOT R!CE B!TCH's Avatar
I have a 2010 fit manual can you use a motor from a automatic fit in a manual car will this work need to know asap going to pickup motor tomorrow
Old Oct 29, 2025 | 03:02 PM
Red 05's Avatar
Yes but it's not a straight swap. The oil pan is different, wiring harness isn't the same. You'd need to pull that off your existing manual engine and transplant it to your donor motor.
Old Nov 26, 2025 | 09:05 PM
dwtaylorpdx's Avatar
Basically you can swap the "long block", just assume you'll have to strip the motor you got out of the car and put the parts and accessories on the new motor, I found that the harbor freight hydraulic table cart is super handy for a place to work on the motor.
Link:https://www.harborfreight.com/500-lb...art-70726.html
I used this to swap the engine out of my 911 when I sent it in for rebuild, since the engine had to go out and in from the bottom. (I was using a portable lift with about 4 feet of lift capacity and the cart will lift high enough to make going back in easy, I's recommend this for transmission work on a lot of cars. Its just a handy portable table in the garage..
alucard07FIT
Sep 15, 2024 01:17 PM
Billyp1966
Jun 22, 2021 09:51 AM
Owl
May 12, 2016 12:49 PM
breadman
Sep 16, 2010 02:09 AM
hardhatz
Jun 2, 2008 10:10 AM
