Any MPG reports yet?
Old Dec 7, 2008 | 12:44 PM
  #241
p nut's Avatar
Yes. Nissan was also being sued. I've already said the factory odo is off. Thanks for clarifying.
Originally Posted by niko3257
as for topping the gas tank off. yes it's not recommended
but it's been done. to do it twice is not going to hurt
the car.
read here for more info.
Fit gas tank info topped off - CleanMPG Forums
also read here
Scan Gauge II accuracy on Fits - CleanMPG Forums
If it's not recommended, DON'T POST TELLING OTHERS TO DO IT!!! Why not tell people over-revving is fine. "It may not hurt the first couple times, so it's fine."
also i didn't say you ahve to run it to E.
previously....
fill it to the top. drive your tank to E and then fill to the
top again.
Old Dec 7, 2008 | 01:20 PM
  #242
Juliane's Avatar
nobody said it's effected by it.
we are just saying in order to get the most accurate reading
on how many mpg you get you have to fill it up all the way.
if you only fill to the first click at the pump you don't ever
know how much you put in every time. it could vary.
You take what you put in, say 8.7 gallons as the pump says, and write it down. Then you drive however many miles you want to, and fill up the tank again. You take your miles between fills and divide by the number of gallons used. That's pretty much it. You can do this with 1/4 tank of gas in the tank, it doesn't matter.
The amount you put in is told to you by the gas pump. You have to trust the gas pump in any case - you can't do anything about a small variance anyway.
Forcing gas into your tank is doing nothing except making it very likely that you will ruin something in your engine.
Old Dec 7, 2008 | 03:45 PM
  #243
Ein's Avatar
Ein
Originally Posted by p nut
Good to hear that somebody ACTUALLY have done some tests. However, I pose the same question to you. How do you know that the Scangauge is more correct than the BSM?
I am not saying one is more correct than the other, but I am just trying to playing devil's advocate to try and figure out which method is actually correct. The manual calc. COULD be more correct. The BSM/SGII COULD be more correct. So far, I have not come to any solid conclusions yet.
My Acura MDX has an option to manually calibrate the odometer (through the NAV). Not sure if this is the case with the Fit's.
The Scangauge is not more accurate. But it allows user to input error correction. When I fill up a tank. I can tell Scangauge the actual amount of fuel used. Overtime, the accuracy is within 2-3%.
How one prove the BSM is more accurate? Travel a certain distance and fine out how much actual fuel used?
The manual method is the most accurate. How simple can it get? Miles traveled used divided by fuel used=MPG. It's best to use the same pump every time.
When there is a 10%. Something is not right.
Old Dec 7, 2008 | 04:58 PM
  #244
p nut's Avatar
Yeah, that is good that the SG allows for adjustments. Still yet to confirm about the Navi in the Fit's ability to do so?
That is the golden question. How much gas was used? Do you trust the BSM/SG computer or the auto-shut off mechanism at the pump? The mileage will be a constant in both cases.
Old Dec 16, 2008 | 02:57 PM
  #245
jimvoorhies's Avatar
I'm seeing a declining trend in my mileage over time in my 09 base AT. I thought the initial difference after the first fill up might have been due to the dealer using pure gasoline, or a better quality one than I've been using, but the reslts from using gas at two stations shouldn't be this big. The first tank was 37.3, the second dropped to 35, then 33, 32 and now 26 mpg.
Old Dec 16, 2008 | 03:17 PM
  #246
raigomaru's Avatar
I've had my fit for just over a week now and here's the result from my first fill-up.
Calculated: 35.9 mpg
Trip computer: 38.8 mpg
This is with 60/40 % freeway/city driving. A good portion of which includes stop-n-go on the freeway. I expect the average to drop to about 33 mpg once it's broken in and I start playing with the paddle-shifters
Old Dec 16, 2008 | 05:31 PM
  #247
CrystalFiveMT's Avatar
That 26 is very suspicious, though there could've been some variable during that fill up, so I would toss that one out.
32 is still good if your driving is mostly city. If that's your highway mileage I would be very concerned.
Old Dec 16, 2008 | 05:44 PM
  #248
JDM_DOHC_SiR's Avatar
So far I have gone through 4 tanks of gas with 80% Highway 20% Surface streets driving and have the following MPG
Tank1 46 trip computer/ 42 calculated
Tank2 45 trip computer/ 42 calculated
Tank3 42 trip computer/ 40 calculated
Tank4 43 trip computer/ 40 calculated
Old Dec 16, 2008 | 06:25 PM
  #249
jrlnc's Avatar
Thumbs up Pretty good numbers!
Is yours an m/t or a/t? Is your gas E-10 (ethanol blend)? These are very important details.
Old Dec 16, 2008 | 06:28 PM
  #250
Lightbulb
A/T and whatever gas the good ol` state of California uses... more than likely E-10.. but not sure
Old Dec 16, 2008 | 06:52 PM
  #251
09 Fit's Avatar
California generally does not use E-10 unless it is posted. 87 octane is standard.
Keep in mind that not all pumps auto shut off at the exact same place so sometimes your tank may get a little more or less. Averaging these fill ups is important.
Old Dec 16, 2008 | 08:20 PM
  #252
raigomaru's Avatar
Being an environmentally friendly state, I was under the impression that the majority of gas sold in CA had E10. I also thought that CA was in the process of, if not already complete, switching to only E10.
hmm...
Old Dec 16, 2008 | 08:52 PM
  #253
09 Fit's Avatar
hmm...
My Bad.
You are correct. California began using ethanol in 2003 with the ban of MTBE.
Most gas stations sell about 6% ethanol.
Old Dec 30, 2008 | 11:24 PM
  #254
rehkopf's Avatar
well 1st 5 tanks getting between 29.22 and 30.51 mixed mostly city, gauge seems to be off around 10% give or take, not as good as most i see unless some shananigans is going on
Old Dec 31, 2008 | 01:30 AM
  #255
tdesi420's Avatar
Just filled up my first tank and got about 31.7 MPG, mixed with a bit more city than highway driving.
Old Dec 31, 2008 | 09:17 AM
  #256
Juliane's Avatar
There are no shenanigans going on. I have an 08 and I have never yet gotten 30 mpg in mostly city driving. We have ethanol in our gas and it cuts the mileage noticeably. I never expect to get over 35 mpg even in highway driving. I just don't. I won't cut off the motor and glide down hills (not that we even have any here). So extreme driving techniques r not me.
I still love my car, but I'd be even happier if I could get 30 in the city.
Old Dec 31, 2008 | 06:04 PM
  #257
Ein's Avatar
Ein
You don't needed to shut off the motor going down hill to save gas. Anytime your Fit is coasting and rpm is above 1.5K no fuel in going into the cylinders.
Old Dec 31, 2008 | 06:18 PM
  #258
HG_OK's Avatar
09 sport AT, first tank averaged 32
Old Dec 31, 2008 | 06:36 PM
  #259
zakurie's Avatar
JDM
How are you driving to get numbers like that?
Old Dec 31, 2008 | 08:33 PM
  #260
victorSCP's Avatar
My Bad.
is this why i dont get mileage average over 30?
