How to change license plate lights?
Old Jan 22, 2009 | 01:04 AM
qbmurderer13's Avatar
Hey guys, im looking to change the license plate lights and am not exactly sure how to change them. Checked the manual and found nothing, also tried a search and found nothing. Do I just have to remove the hatch panel? Wanted to make sure before I go and rip it off.
Old Jan 22, 2009 | 07:32 AM
Committobefit08's Avatar
Its actually pretty easy (even though its a small area to work in.) From the outside pop your hatch and hold it eye level. If you look at the clear plastic cover over the bulb there is a very small arrow on the left side of it and points to the right. All you do is slide the plastic light cover to the right and the cover pops right off (might need some finger strength mine were on there pretty good). Then press the tabs on the clear cover to release the attachment to the base of the bulb. Then of course just pull out the wedge bulb out. Just repeat on the other side.
To get it back it just get it back in the position and it should just snap back in.
Hopefully this helps.
Old Jan 22, 2009 | 10:14 AM
ken_vs_ryu's Avatar
led bulbs from where?
Old Jan 22, 2009 | 10:31 AM
I got mine from...
http://www.superbrightleds.com/mini-wedge.html
WLED Car Bulb specs
I got these.... WLED-CW5 Cool White
I love them.
Old Jan 22, 2009 | 02:31 PM
Thanks for the help. Do you have pictures of your setup?
Old Jan 22, 2009 | 02:37 PM
No sorry not yet of the back.
If I remember tonight I will take some pics.
I did take one of the top city lights they are the exact same wedge led though.
They look a little more blue in the pic. I think it was because of the camera. They are closer to a white light in person.
Old Jan 24, 2009 | 12:11 PM
pinoyfitpilot's Avatar
here are my licence plate LED lights on
not the absolute best photo out there, but the main point comes across. my plates were not home the day the photo was taken but are here now. you can also sorta see it in my signature photo. let me know if you'd prefer to see a photo with plates.
Old Jan 24, 2009 | 02:10 PM
Looks pretty good. Looks more blue than I want mine to look but maybe its just the camera. I got my lights coming in from superbrightled's. Ordered 6 of the cool white. 2 for the license plate, 1 for the cargo light, 1 for the dome light, and 2 more for the map lights. Ill take pictures of all of these soon as I get em done.
Old Jan 24, 2009 | 03:47 PM
panda1314's Avatar
can you state the type of bulb you used for each swap? i'm interested in doing the above change as well
Old Jan 24, 2009 | 04:20 PM
reako's Avatar
I replaced my license plate bulbs as well. I wanted roughly the same amount of light output, white in color, with no blue. The bulb type is 194 wedge. I first tried these which were too bright for my tastes and also blew a fuse: 194 Size Car LED Bulb. These would be better up front for the top corners of the headlights (also 194 wedge type bulb).
However these were perfect for me: 194 Size Car LED Bulb
I can upload photos and update this post later tonight, but the links above also have photos of these bulbs in action if you click the tab "Action Shots".
Old Jan 24, 2009 | 10:02 PM
713_fit's Avatar
I to want to change out my licnese plates to LEDS.
they blow fuses?
is there something i need to do like add resistors or anything so i dont blow fuses?
Old Jan 24, 2009 | 11:33 PM
Pinoy: Thanks for adding the pic. I never got a chance to load my pic of my rear end up. Mine looks just like yours. (of course with a license plate though)
Old Jan 24, 2009 | 11:34 PM
they blow fuses?
Nope just plug and play.
Just make sure they are wedge bulb 194 Leds.
Old Jan 24, 2009 | 11:37 PM
reako's Avatar
they blow fuses?
No, generally they don't. However, I believe one of my LED's came from the factory with some type of internal polarity issue (Oznium.com gave me a full refund). I believe the only time you need to add anything is if you are replacing one of the blinkers. You really need to be careful here because if you blow this fuse it takes all your tail lights with it....not to mention I could only find a replacement fuse at the Honda dealer.
Old Jan 24, 2009 | 11:49 PM
reako's Avatar
Pics as promised....
As you can see the color temperature is very white, and the light output is not overwhelming. My goal was to get something that looks as white as the cold cathode tubes that Lexus uses for their license plate bulbs...I am happy with it so far!
Old Jan 24, 2009 | 11:52 PM
713_fit's Avatar
reako..where did you get ur leds from?
i like the whiteness..but it isnt that bright..i want brighter...but i dnt want it to look like blue either
thanks!
Old Jan 24, 2009 | 11:55 PM
reako's Avatar
thanks!
Oznium.com.....if you want a similar color temperature, but ridiculously bright... get these: 194 Size Car LED Bulb See my post #10 in this thread for more info.
Old Jan 25, 2009 | 12:00 AM
713_fit's Avatar
thanks!
kind of off topic, but if i do reverse light, would i need to add anything extra things or just simple plug and play to?
Old Jan 25, 2009 | 12:21 AM
jdmsneakerhead's Avatar
nice finally i can change the bulbs!!! love how they look on ur car reako
Old Feb 17, 2009 | 09:51 PM
lxwhite's Avatar
yea i just changed mine... the type that only emit light on the side instead of all around... but i broke one of the clips of the light cover when sliding it to the right... used a little tooo much strength... so be careful of tat guys... but love how the light isnt too strong... i wonder if i can get a replacement cover?
