Nitrogen for my tires. Good idea or snake oil?
Old Jul 31, 2009 | 04:07 PM
12vltfrk's Avatar
Originally Posted by kenchan
high perf cars use nitrogen as the expansion contraction ratio is lower vs regular air.
but on a car like ours, just use regular air and just keep checking tire pressure once every 2-3wks. you can visually check every morning too before leaving for work.
thats why i wld do it
Old Jul 31, 2009 | 04:15 PM
FITFOLLY's Avatar
Wow I got an education today, I never knew people did this..
Old Jul 31, 2009 | 09:56 PM
mahout's Avatar
Originally Posted by largeorangedrink
I plan to run 40psi in the tires of our new fit. Would it be worth the price to put nitrogen in them or is this service just bullcaca.
While nitrogen molecules are larger than oxygen molecules and should leak through tire sidewals less easily, the supposed advantages are way far out on a limb.
The reason racers use nitrogen is the coeficient of expansion doesn't change as much with temperature as air (80% N2) you're not likely to run your tires at 200F+ where the difference matters.
Its all marketing.
Old Aug 1, 2009 | 01:03 AM
raytseng's Avatar
If your tire place has it for free, get it, there's no downside to it.
But don't pay for it, or go out of your way.
Old Aug 1, 2009 | 04:07 AM
rosswond's Avatar
Originally Posted by Mr. Reliability
PV=nRT is the same law for all ideal gases. Whether a gas can be treated as ideal is issue, and humidity does affect that.
QFT - and that's why it's important for service stations to maintain their compressors properly, so they don't spit oily rusty water into your tyres along with the air. Probably the oil is more dmaging to tyres than the water actually. IF you get air from a well maintained compressor, with a properly maintained dryer, it's just as good as straight nitrogen from a bottle.
That's a pretty big if though...
Old Aug 1, 2009 | 10:02 PM
landers7222's Avatar
Anyway, when a wheel shop changes the tyres, it is not done in a "humid free" enclosed place, so in reality, before N2 is pump into the tyre, there's already "Air" inside unless it has been "suck" out completely, so you would only get about 90% max of N2... jut my 2 cents worth..
Old Aug 1, 2009 | 10:18 PM
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
Originally Posted by spreadhead
I use an 80% nitrogen mixture in my tires. It's called compressed air.
lawl [10 characters is so stupid. **** you FitFreak]
Old Aug 4, 2009 | 01:57 PM
jelliotlevy's Avatar
Smile
Air = 80% Nitrogen + 20% Oxygen + trace amounts Xenon, Krypton, Argon. Unless your Nitrogen is fortified with those trace elements, which help build much stronger and puncture resistant tire sidewalls, you are just not getting your money's worth.
Old Aug 4, 2009 | 05:17 PM
BullFrog's Avatar
Pretty much snake oil for the average motorist. Jay Leno lost whatever limited credibility he had with me as an automotive "expert" when he started peddling N for daily driver auto tires.
If reduced leakage with N is correct and I believe it is, then after several refillings of your tires with regular 80% N air the % of N in the air should exceed 90% which is probably all you are going to get in a typical N fill (normal air is already inside of tire before you fill with 100% N).
However dry air is important for tires, painting and air tools. I have an electric AC style dehumidifier unit for my compressed air that I use for painting whenever the reduced moisture may be critical and I can use this if the local humidity is high that day. Otherwise I don't worry about it.
If you live in a humid location, you can approximate the same results by coiling up 50 feet of cheap plastic PVC air hose in a drywall bucket. Arrange the output of the hose to go through the side wall of the bucket at the bottom. Seal the hose exit with silicone RTV. Fill the bucket with cold water. The water will condense in the hose into droplets and run down inside the hose to the bottom. Put a water trap on the output from the bucket to catch these liquid drops and you will have much dryer air available for tires, painting or air tools.
In a shop arrange your air lines to run around the shop walls to cool down and to drain condensed water in the lines to a low point where a drain valve is located. Then run the output lines up from that location. Also add a simple liquid water trap immediately after your air compressor and at the end of the cooling lines. Keep the traps and the compressed air tanks drained if you don't have automatic drain valves.
You only need the fancy refrigerated AC type dryer for some of the critical paints, not for your tires or air tools.
Old Aug 4, 2009 | 08:42 PM
Texas Coyote's Avatar
Great info BullFrog.... Thank you very much for sharing the bucket drier trick.
FitFrack
Sep 19, 2015 11:55 PM
Vash
Nov 3, 2011 06:52 PM
tigerbunni
Jul 25, 2011 03:34 PM
polokid69
Oct 13, 2009 02:05 PM
triton.
May 10, 2009 05:49 PM
