First long trip on highway
Old Jan 8, 2010 | 12:09 AM
dgs's Avatar
dgs
Originally Posted by Shockwave199
I'm not surprised. I can do 80 without even noticing. The Fit can do high speed no problem. It takes a bit to get up to the high speed but it'll keep up and then some.
Dan
For me this has been the most surprising thing about the Fit. It takes a little bit to get to 85 mph or 90 mph but like you say, it will hang out at those speeds all day long with no problems. The engine is turning higher rpm's than I would like which would be cured with a tall sixth gear, but even without it there is no problem going fast in this car. Very stable at high speeds.
I'm pretty anal about keeping my tires inflated to 33 psi, which is the recommended level. I check them every week, or when there is an extreme temperature change. If you're going to drive at high speeds for extended periods of time I can't recommend enough to make sure the tires are inflated to factory specs. A blowout at 90 mph in a little car like the Fit would be ugly.
Old Jan 8, 2010 | 07:46 AM
specboy's Avatar
Originally Posted by awptickes
5500 RPM is where the rev limiter cuts out on the GE8. That's about 120MPH, and when you hit it, you'll know instantly. The fuel cut isn't much fun. It pisses me off every time I hit it on the track.
I found that my fit, even in stock trim (stock wheels, tires, alignment, suspension, brakes) was completely stable at that speed. Now with lightweight 15x7 wheels, and extremely sticky tires, mugen sport suspension, and -1º camber, I find that it's a bit more stable.
The Fuel Cutoff is above Redline on the Fit but I'm sure the fit is Electronically controlled to not go over a certain speed. This is the way it was on my altima. My 3.5SE was limited to 142mph and the 3.5SL (same engine/trans/etc...) was limited to 117mph(because of the tires and suspension) Unfortunately for SL owners, just swapping out tires and suspension wouldn't change the Electronically controlled limit.
SideNote:, I don't think I was ever over 85 in the altima. I was just a member of the forum and I DO NOT condone testing what the speed limiter is on a car... especially not around me or my wife and I'll hate you for life if its done around my son. (He's 3)
~SB
offroadcmpr
Jul 11, 2013 09:41 AM
Shockwave199
Dec 14, 2010 09:29 PM
der Mond
May 13, 2010 08:30 PM
marano35
Nov 8, 2008 09:58 PM
Rdean58
Sep 7, 2007 12:29 PM
