Bluetooth HFT with display 08E00-E10-600
Hello. I'm look for installation instruction for handsfree with lcd 08E00-E10-600
http://img203.imageshack.us/img203/9673/5061.jpg http://img251.imageshack.us/img251/8101/5062x.jpg http://img251.imageshack.us/img251/8.../9673/5061.jpg |
YO that is nice!!! what is that silver knob underneath the driver side cup holder?
this is the first time ive seen the LCD display |
Originally Posted by lilaznphatboy
(Post 806793)
this is the first time ive seen the LCD display 1. "Press" - activate the function. "Long press" - back to previous level. 2. Rolling the scroll wheel to access the menu 3. "Double press" - when during a call, double press can access the Microphone Mute and Transfer function |
that looks like something available only on your
side of the earth:D i don't think anyone here would have anything like that for you. then again i might be wrong. |
When I searched the part number, I saw references to the insight as an accessory. (not here in the US). You might want to check out some insight forums to see if there are any DIY's there. granted it won't help completely with the Fit, but may help with wiring. also check out the CollegeHillsHonda.com website for instructions on how to add bluetooth to the fit (using the ceiling mounted kit) as it might have Fit wiring information that you may need to reference. (that you won't find on the insight forums) If you find it and Do it up... be sure to take photos and post it here.
~SB |
Good MorningThe following are the part numbers for the Honda Jazz Bluetooth kit without navigation?
