some 09 FIt Issues, any IDEA?
Old Mar 23, 2010 | 12:56 AM
canuck901's Avatar
I had a few issues with my 09 FIT, one is the ignition key wouldn't turn, i tried the key for about 3 minutes, nothing, all the lights worked, and what not, it was in the ignition locked, i could take it out but not turn over the car.
I waited about 3 minutes...then it worked.
Any idea what the problem was? first time it has happened to me.
another question is when I drive the doors automatically lock at about 20mph, then when I stop the car just the drivers doors unlocks automatically and I have to unlock all the doors with the remote or switch lock, is this normal?
my Fit has is a Sport with Navi
Old Mar 23, 2010 | 01:02 AM
eaglerugby04's Avatar
Try turning the steering wheel when you are turning the key. This should fix the problem.
As for the locking. It is an option in the manual that you do. I dont remember how i did it, but you can set park to unlock all the doors instead of just the drivers door.
Old Mar 23, 2010 | 01:09 AM
esamson7's Avatar
yeah turning the wheel a bit will allow you to turn the key.
to unlock all your doors...https://www.fitfreak.net/forums/2nd-generation-ge-08-present/31098-unlock-my-doors-please.html
Old Mar 23, 2010 | 01:27 AM
canuck901's Avatar
I did turn the steering wheel! the key just wouldn't turn over, it was weird!
it ended up working so not a big deal...
yeah, i guess its a manual setting for the door locks auto
thanks for the tip, i just saw those settings in the manual about the auto locks
Old Mar 23, 2010 | 09:55 AM
specboy's Avatar
ok... so the Key wouldn't turn? or the car wouldn't turn over? (two very different things). if the key won't turn, that's the steering wheel lock mechanism and turning the wheel should release it. If the car won't turn over (but the key will turn), it could be a number of things. In the 5MT fit's (and any manual trans), the clutch has to be depressed in order to start the car. I'm sure the 5AT has to be in park and the brake pedal depressed to turn over. It could be a simple little switch issue or pressing the brake further/clutch further.
~SB
Old Mar 23, 2010 | 11:30 AM
Sgt Stempy's Avatar
~SB
Poor clutch.. what kind of life is it when you are forced to be depressed in order to work properly...
Old Mar 23, 2010 | 10:25 PM
JustinK's Avatar
LOL, I have never heard that one before.
ksmith0034
May 29, 2022 10:46 PM
upallnight
Jul 9, 2018 11:07 AM
short1
May 3, 2017 08:46 AM
MagicGuitar
Jan 7, 2015 07:07 PM
Aviator902S
Mar 24, 2010 06:16 PM
