Poor Instructions for Installing Driver's side All-Weather Floor Mat
Old Sep 18, 2010 | 12:07 AM
moobear's Avatar
I bought my black 2009 Honda Fit in the last days of the Cash for Clunkers program. Literally, I walked in on a Saturday, there was one Fit left a traded in my mother's old Lexus and picked up the car on Monday! So decisive, so unlike me! A few months ago I decided to get the all weather floor mats from Honda. I was chagrinned to see that the drivers side mat needed to be installed to prevent it from slipping. But I have found the instructions to be most confusing. They say that the slits are to be located and they prescribe cutting out squares of carpet to introduce the hooks. However, when you lay the carpet down with the hooks in the position they would take, the seems to be no need to cut a square out of the carpet. It seems to me that you only have to make two parallel slits for each clip, the correct distance apart (2.9 mm, I think). Also, does anyone know if you have to cut out some of the insulation substrate under the carpet (as illustrated on a YOutube video) in order to have room for the clip to fit under the carpet? I am afraid that my question is as convoluted as the instructions! But if anyone has found this frustrating, I would love to know about it.
Thanks,
Tom
Old Sep 18, 2010 | 12:25 AM
hogwylde's Avatar
It was a pain for sure. What I recommend (and how I did it) is you will see the outline in the plastic where you are to cut the slits. Then get a straight razor from an X-acto knife and cut between the carpet and the plastic. Essentially cutting the glue from the underside of the carpet to slide the clip in. It's a pain to maneuver the clip into the slit but it will go.
Old Sep 18, 2010 | 10:16 AM
Krimson_Cardnal's Avatar
Here's the instructions: http://www.bernardiparts.com/Images/...s_AII42172.pdf
The starter slits are there - you need to feel the carpet to find them. The install has a video clip built in.
Old Sep 18, 2010 | 03:17 PM
moobear's Avatar
Problem solved!
Thanks to both ofyou for clearing this up for me. I now understand the directions and must admit that they are pretty straight forward. Once I saw the demonstration video, it all made sense. I will let you know how it all goes. Thanks again!!
Old Sep 18, 2010 | 03:31 PM
CrystalFiveMT's Avatar
It was simple for me. Took 10 minutes, but if I were to do it again it would take 5 mins. But the instructions do look a bit tedious.
Old Sep 18, 2010 | 11:45 PM
Fitfreaks is friends.
KRAFTYDIN
Toronto Community
May 6, 2011 01:08 PM
swebob
Nov 9, 2010 12:28 AM
igor17
Apr 25, 2010 03:36 PM
john-fit
Oct 7, 2009 08:29 PM
Jonniedee
May 18, 2006 09:49 PM
