any advice for cleaning engines?
Old Jul 8, 2011 | 08:54 AM
Krimson_Cardnal's Avatar
Welcome to feakworld - keep it shiny. Here's a good place to start: https://www.fitfreak.net/forums/fit-...-any-tips.html
Old Jul 9, 2011 | 12:12 AM
Paul56's Avatar
I am not a fan of spraying water in the engine compartment.... simple because electrical hardware and water generally do not get along well and sometimes the problems caused do not surface for quite sometime.
Years ago when the engine compartments were simple it was easy to avoid spraying the very few areas with electrical hardware and back then that is exactly how I cleaned the engine bay. Cover the alternator & distributor, remove the battery & spark plug wires... then go at it.
You fellas living in the salt belt end up with grimy engine bays in the spring that need lots of persuasion to return to the former luster so perhaps some well directed water in certain areas.
Me being in Texas... unless I have leaks under the hood all I see is a collection of dust in there that compressed air and a swipe can remove.
Old Jul 18, 2011 | 12:18 AM
monster_mugen's Avatar
I've always hand wiped everything with Meguiars Quik Detailer...It's not like it's a huge engine bay!
Old Jul 18, 2011 | 12:33 AM
myblackhatch's Avatar
303 aerospace protectent..........
on all plastics and cawl when your all done and everything is dry.
User1
Nov 14, 2017 07:52 PM
luciusad2004
Jul 14, 2013 03:52 AM
EXT
Jun 18, 2012 12:57 AM
Edwood
Dec 21, 2010 03:54 PM
madhartigan
Oct 21, 2008 08:35 PM
