Stock Sport Rims???
Anyone know the specs of this rim? I need the width and offset.
I know they are 16" but don't know the rest. Thanks |
16x6", ET+53, ~18.5 lbs.
I wish more people would use forum search, though. ;) |
I assume ET means offset at +53mm? I ask because I am looking at some rims 16x7 with +40mm offset and plan to use 205/50/16 tires. Will this setup work?
Yeah, it's +53mm. Depending on how low you go, that may not work because it will probably rub.
Originally Posted by Vanct
(Post 1018677)
Not changing height, what do you think will rub the front wheels when turning? |
+45 or higher is safe, but some people start rubbing tires any lower, depending on the setup. Since you're not lowering, then you won't have to worry.
This is 40mm offset so we will see...
