? for any one with sportlines
Hello everyone and thanks in advance!
I'm planning on lowering my car on Eibach sportlines in the future and would just like to know if the camber bolts are required to align the fronts properly. I used the search but couldn't really find a definite answer. I'm on stock wheels and tires and have no plans of changing the wheels in the future. So...do I need the camber bolts or should the alignment shop be able to do the alignment without them? Thanks! |
If you're on stock tires and wheels, you won't need camber bolts on those springs.
great thanks!
One more question. If lowered on sportlines and using the stock sport wheel, will 205/50 tires rub?
it won't rub with that size. you've got plenty of room if you leave the offset stock.
Awesome thanks again fellow fitfreaks!
