My 2011 Honda Fit "Severe Service" journal...
Old Oct 29, 2011 | 10:46 PM
  #81
Krimson_Cardnal's Avatar
My mistake jjsifo sorry bout that man.
Old Oct 29, 2011 | 11:36 PM
  #82
jjsifo's Avatar
Oil change
Originally Posted by specboy
what % was the MM at when you changed it at 1200 miles? 80%?
As for oil change costs, I've said it before. My Local Honda Dealer here in VT charges me under $40 for a Full M1 Synthetic oil change. They advertise a package deal as well for $53 on any vehicle (up to 5 Qts which is most any honda) which includes a few extras. It's on their web page...
Severe... Please stop posting info like it is Gospel. Posting your experiences is one thing but posting them as if they were cold hard facts is another.
Why is this thread in the GE General section anyway? Shouldn't it be under the reader's rides section?
~SB
YES! 80% just could not resist not to go with synthetic.
Old Oct 30, 2011 | 06:57 PM
  #83
MiMi1's Avatar
Bay Ridge Honda charges 31$ for an oil change and you are out in 45 mins.
Did I mention they are open till midnight M-F?
Gotta love Brooklyn
Old Oct 30, 2011 | 09:26 PM
  #84
SevereService's Avatar
You guys are right. If you maintain your vehicle well with full synthetic then the dealership wont care on the trade-in and neither will the insurance company if you get your car into an accident. If you plan on trading in your vehicle, then I would suggest finding the cheapest oil change place you can get away with.
In a private sale, receipts and maintenance do matter. If I were looking for a car on the autotrader, it would be somewhat important to me.
My purpose is to take this car to as many miles a possible. So Im going to be anal with the maintenance and use the best oil available which is the full synthetic. Im not sure if it will make a difference or much of a difference, but I want to get at least 200,000 miles out of this car. I dont want to get another car for quite a while. Sometimes there are things that happen in life and I may need to sell this car earlier then that...in that case I want to have a trail of receipts to make it easier to sell.
Many people will probably be better served going to the Firestone place to get their oil changed which is cheaper or an independent mechanic. I guess for at least the first 35000 miles Im going to the dealer so I can keep that paper trail.
Old Oct 30, 2011 | 10:34 PM
  #85
I'll dare mention that Honda is rather specific in keeping the factory fill oil in the crank for a full oil cycle by the MM during engine break-in.
Old Oct 31, 2011 | 08:23 AM
  #86
jjsifo's Avatar
Oil & break -in
They are.I should have waited a bit longer.Will probably leave that 0-20 M1 in there till the end of January.Winter here is a mild summer elsewhere, but to much stop & go and work is only 20 min ride,(a 20 min Grand Prix), take care man. JJ
Old Oct 31, 2011 | 04:55 PM
  #87
Probably not critical, but when I got the FIT it was one of my first questions to the service department on the day I picked it up. I then researched it have discovered that on some engines a dino oil break-in is recommended. Honda feels this way, at least on the 2010 Fit I bought. I was told to go two oil cycles then switch over.
Now the 2011's + have switched to 0W20 oil, but it's not clear to me if it's synthetic. If they are recommending synthetic oil per owners manual then things have changed.
Old Oct 31, 2011 | 05:20 PM
  #88
Yes it is 0W-20 semi-synthetic. I dont know of anyone who makes 0W-20 semi-synth but Kendall. Correct me if Im wrong. I believe the dealership semi-synth is Kendall because who else makes it? I checked and couldnt find Mobil or anyone else.
I use the fully synthetic version. Kendall Motor Oil is what Firestone dealerships use.
Old Oct 31, 2011 | 06:44 PM
  #89
Trick is what does the owners manual say.
Break-in Period is clearly explained in the 2010 manual stating, among other things: "Do not change the oil until the scheduled maintenance time."
Synthetic oil can be used if meeting the recommended grade and API Certification.
Point I'm making is the importance of keeping the factory oil in for a full cycle.
My dealer said go two cycles then change over - Honda Engineers are particular on engine break-in procedure. Recommendations were supported by my own research into oil mfg and forum searching.
Remember, I'm talking about the factory fill oil in your car's engine as it is delivered to you.
Old Oct 31, 2011 | 08:05 PM
  #90
jjsifo's Avatar
oil
What you are stating is probably very true.I keep thinking, does this or would this apply to normal driving only ? my driving is anything but normal, that little engine has been seeing an almost constant life between 5k and 7k rpm,this has been going on since past the 500.0 miles.I guess time will tell how much the break in period was messed up, if any.
Old Oct 31, 2011 | 08:41 PM
  #91
littleblackcar's Avatar
Originally Posted by Hapa DC5
My dealer charges me $10 for labor and a crush washer on an oil change. I bring my own oil and filter.
They also wash it for free. Tire rotations are $20. Might be a better solution for you.... I also change my oil once it hits 20% on the maintenance minder.
I change the air filter and in-cabin myself once per year. Cost me a whopping $40 for the two. I could DIY my oil change, but I like the fact it shows up on Car Fax that it was "dealer serviced."
Do you think most dealers are cool with someone bringing in their own oil and filter? What kind of oil did you use?
Old Oct 31, 2011 | 08:44 PM
  #92
specboy's Avatar
The nice thing about the Maintenence Minder is that it takes all of these things into account, it's not a Mileage only reminder but it monitors environments in the car and adjusts it's schedule based upon use. "Normal" doesn't apply here.
~SB
Old Oct 31, 2011 | 08:49 PM
  #93
Originally Posted by SevereService
I am right now at 24000 miles on my third oil change. I have changed the oil each time the Maintenance Minder has reached 15% without fail. This time I went to my local Honda dealer, Mahwah Honda in Mahwah NJ, and told them exactly what I wanted. I wanted the oil changed (with my Honda full-synthetic oil), a new oil filter and the tires rotated...they charged me $50. There are many threads on here of guys getting their oil changed at the dealer for a really low amount, but I have not been able to find any cheap Honda dealers...and I have been to 4 of them by now. Dont believe what you read in the forums...if you pull your vehicle into the Honda dealer then be prepared to spend. Firestone dealerships use the same oil which Honda markets and it costs you $60 with fully synthetic oil (not the semi-synthetic bulk stuff the dealership uses). My concern is keeping the Carfax clean showing maintenance consistently at the dealership in the event I need to sell it.
As I left the dealership snow was coming down...the first of the season and it was a mess outside. I thought that with my half-worn Dunlops, the original stock tires, which every forum has spewed venom upon would not be good in traveling in this weather. The Dunlops have 6/32nds of tread left which is the bare minimum recommended by most tire manufacturers for snow climates. I traveled about 30 miles while it was coming down hard and I found the vehicle to handle the snow better then other cars on the road. The stability assist kept kicking in and never did I feel like I was going to get stuck. There were other vehicles on the road traveling with their hazard lights on, but I just went around them laughing.
I have the Base fit which has the skinny 175s on steel wheels which handle a lot better in the snow then the Honda Fit Sport which has 185s on alloys. I imagine if I had the newer Yokos then the car would have handled even better. I didnt need four wheel drive, emergency lighting systems or an SUV...I just needed the Honda Fit with its traction control/stability assist.
So you're going to stick with stock tires this winter? I'm debating between my stocks (which are new---850 miles) or Blizzaks, which I really can't afford.
Old Oct 31, 2011 | 08:54 PM
  #94
specboy's Avatar
LBC, Stick with the Stock tires this winter and go with Snows next. In NC, you don't need the Blizzaks or anything that good. Go with the winterforce tires or some cheaper snows as you really don't need much more than an all season. Here in VT, I ran the OE Bridgestones for the first Winter. Did the same on our altima (also Bridgestone turanzas) and after that, I went with Snows on both. especially since you have so little miles on your OE tires, there is little reason to spend the money on Snows.
~SB
Old Oct 31, 2011 | 09:44 PM
  #95
~SB
The Dunlops that are on there look pretty good. If only I could make everyone else stay off the road, then winter wouldn't be such a pain. -)) I was even thinking I'd move to Florida---but no way! Just a momentary lapse.....I love having the four seasons of the mountains. We do get snow and slick roads, then you throw in the hills---it can be a mess. Good idea to wait until next year and get snows, though.
I living in Huntington VT about 12 years ago. I had a rear-wheel drive pickup; I put studded snows on it and I was probably the slowest driver on the road to Burlington! Beautiful, though--and at least New Englanders know how to drive in snow, unlike people around here in western NC!
Old Oct 31, 2011 | 10:39 PM
  #96
My feeling is it's probably not a critical issue, just that the OP is quite concerned w/ 'going by the book'.
You fly planes and most likely have a better understanding of reliable engine performance than most. Comfort is knowing your Fit isn't going to fall out of the sky.
Honda Engines are near bullet proof by reputation.
Expect a long service life and enjoy the ride ;-)
  #97
nickemangione's Avatar
after some research it looks like the 0W-20 comes in conventional, semi-synthetic, and of course the full synthetic.
Old Nov 1, 2011 | 10:05 AM
  #98
FitStir's Avatar
Gotta love Brooklyn
Damn... Midnight? Even though it's a bit of a ride, might come in handy some times. Thanks for the info.
Old Nov 1, 2011 | 08:33 PM
  #99
SilverBullet's Avatar
Dont think it come in conventional, but ConocoPhillips supplies the semi-synthetic and synthetic oil to Honda.
Old Nov 1, 2011 | 09:09 PM
  #100
http://www.handa-accessories.com/civmaint01.html
If you go to where the cases of oil are on this page you can see that there is a 12 pack case of 0w-20 for $41....this is the conventional.
