Unofficial Honda FIT Forums
Unofficial Honda FIT Forums (https://www.fitfreak.net/forums/)
-   2nd Generation (GE 08-13) (https://www.fitfreak.net/forums/2nd-generation-ge-08-13/)
-   -   for those with 205 50 16's (https://www.fitfreak.net/forums/2nd-generation-ge-08-13/69175-those-205-50-16s.html)
Santiad Dec 19, 2011 08:19 PM
I have them also (falken ziex 912'4)
Just curious to know what pressure you all keep yours at?
I do 39 but this winter my ride seems harsher than usual.
MikeNSX Dec 19, 2011 09:39 PM
37 front, 35 rear.
climhazzard Dec 19, 2011 10:34 PM
Originally Posted by MikeNSX (Post 1057736)
37 front, 35 rear.
34ish all the way around. I say "ish" because the temperature fluctuates so much lately in VA, it's hard to keep track. (It's said for every 10 degrees fahrenheit you increase/decrease 1PSI, which I've found to be very true).
Codger01 Dec 19, 2011 11:39 PM
35 all the way around. The recommended 33 feels too squishy.
Texas Coyote Dec 20, 2011 12:11 AM
That sounds reasonable... I have found that when it gets cold the oil in the dampers thickens and rubber is less pliable so I have to drop the tire pressure instead of adding more air... I had been putting 35 PSI front, 31PSI rear with my old 195-55-15"s but the 205-50-16" Goodyear Eagle Authority tires... They are the same tire as Eagle GTs but with a slightly different tread sold only at Wal-Mart.. They are heavier and have much thicker sidewalls than other tires I have had on my 07 Fit... I have dropped the front to 29.5 PSI , rear to 28 PSI but the ride is still rough even when the ambient temperature is as warm as 50, 55 degrees F... I have my rear seats removed so I have to use less air in the rear tires than the front...
RevToTheRedline Dec 20, 2011 09:34 AM
I keep them around 36 or try to at least, seems to ride good.
© 2026 MH Sub I, LLC dba Internet Brands
