Unofficial Honda FIT Forums
Unofficial Honda FIT Forums (https://www.fitfreak.net/forums/)
-   2nd Generation (GE 08-13) (https://www.fitfreak.net/forums/2nd-generation-ge-08-13/)
-   -   '09 Fit: doors don't all unlock properly (https://www.fitfreak.net/forums/2nd-generation-ge-08-13/69484-09-fit-doors-dont-all-unlock-properly.html)
jdufford Jan 5, 2012 03:47 PM
There is something wrong with the door locks on my ’09 Fit. Sometimes, whether I am using the key in the door itself, or using the interior lock switch, not all the doors will unlock. If I am trying to unlock them with the switch on the inside, I have to lock it again, then unlock it, after that all the doors will unlock. It started out with the front passenger door, and that was intermittent. For a while I just thought I wasn’t turning the key fast enough. Now the front passenger door rarely unlocks properly, and the rear door on the driver’s side will do the same thing randomly. Also, I noticed I can hear the electric motors or actuators or whatever they are before I hear the doors lock or unlock. I am no mechanic, but hey don’t sound good. As my girlfriend put it, my “door locks sound like they are sick.” This is a stock, manual transmission, ‘09 Fit, 66K, with no keyless entry or door alarms or anything aftermarket installed.
einstein77 Jan 6, 2012 09:33 AM
I have an 08 and 09 Fit. Both have extremely quick and snappy door locks with the snapping sound. If you're getting draggy sounds out of only a few of them, the actuators are having problems. If you can get to them, spraying ACF-50 directly into them might help bring them back. If they're all slow, then there is "probably" a system problem and would have to be diagnosed better. I think, you and your girlfriend should try to isolate which of the door locks seem to snap "noisily" and go from there.
andysee Feb 25, 2017 06:18 PM
Sounds like the symptoms mine was exhibiting which eventually led first to the superlocking and then to the (apparent) failure of all three passenger locks. Dealer quoted £860 to fix but I did it for £29 as described here... HOW TO: Fix a power door lock
© 2026 MH Sub I, LLC dba Internet Brands
