Stock Dunlops = Fragile?
Old Oct 31, 2012 | 02:22 PM
Wafulz's Avatar
i personal think they suk for my style driving only lasted 13k but for sum one slow or a cruiser there ok but i would never buy ever
Old Oct 31, 2012 | 06:28 PM
mkane's Avatar
More air pressure. We auto crossed ours.
Old Nov 1, 2012 | 01:13 AM
Wafit's Avatar
Originally Posted by kenchan
Sp7000 are not fragile, you probably just had bad luck with debris and pot holes.
Make sure your tire pressure is between 33 and 35. GL.
Ok, this is something that I can try. I usually kept them at 30-32 PSI. I'll bump the pressure up a little. I only have around 13K on the car, and would like to get at least 30K or so out of the Dunlops before I go to Contis.
Old Nov 1, 2012 | 09:17 AM
mkane's Avatar
Switched out our stock tires for a tire with a treadwear rating more suited to our monthly weekends with ESCA. Had plenty of tread left. These tires would have gone 40,000 miles. 35lbs in the front seems like car stabilitys perfect. Freeway driving at speeds above 65.
Old Nov 1, 2012 | 10:38 AM
fujisawa's Avatar
Stock tires are rarely good, especially in economy cars. Doesn't surprise me that Dunlops aren't terribly great, either.
I am not near to replacing my tires, but in general I like Michelins - if you choose the right one, they'll give you a relatively grippy tire with high tread wear and good low-temp flexibility (not to the extent of a winter tire, but that's a separate category).
I know little about tires but I want to spend the next few years learning so that I can get a quieter tire next time :P
Old Nov 1, 2012 | 11:14 AM
yah, that's too low. this time of year when temps are fluctuating, i keep 35-37psi cold. i want to be on the higher end vs lower end.
one can have the best tires, but if the psi is wrong, it will drive like crap. too high or to low, will perform like crap.
Chris Norlund
Jul 29, 2015 10:40 AM
jcfit
Mar 26, 2011 03:37 AM
kbh
Mar 16, 2011 08:35 PM
racing852
Mar 14, 2011 03:17 PM
xonexlifex
Nov 10, 2009 12:28 AM
