Coasting
Coasting
When I am exiting the freeway, and take my foot off the gas, or turn off the cruise control, I notice that my car doesn't seem to coast for very long. It seems there is something that is slowing it down much faster than I would think it should.
I have a 2012 Sport with a little over 18K miles. My last car seemed to go forever when I would do this. There is a spot on my way to work that goes from 60 to 45mph and I usually coast down to 45. In my last car it took much longer to get to that 45mph than in my Fit.
Does this happen to anyone else? Is it mormal? I get great milage. So I don't think the E brake is stuck on or anything dumb like that. I'm guessing that it is just the way the transmission works or something.
Any thoughts?
Any thoughts?
Any thoughts?
Any thoughts?
Any thoughts?
Any thoughts?
There's a couple of reasons.
1. The Fit is fairly lightweight and not very aerodynamic and air resistance slows it much quicker than most cars.
2. The manual transmission has higher gear ratios which aldo tend to slow the Fit more quickly.
Yep to the above, but, if you have an auto and at low speeds (40mph) you can go FOREVER on a flat road! The low-friction, small-displacement drivetrain really shows :P ... I often fetch up to the back of big SUVs that were previously going faster than me, even without throttle.
But on the highway, yes, it loses speed fairly quick. It's like a streamlined brick and the aerodynamics match that.
According to Car & Driver Magazine, the Fit's top speed is 115 mph, drag-limited. Aerodynamics keep the Fit from going any faster, even though there's RPMs to spare before it reaches redline. Yeah, it's a brick. A lightweight brick.
but you wont have engine braking if you do that
