Metal Grinding/Gravel sound when car moving off
Old Jan 6, 2013 | 09:45 PM
Dark_templar's Avatar
Anyone knows what could be the problem if my car has this metal grinding / gravel sound when moving off from a stop and it doesnt always happen. The sound seem to be coming from the engine area.
Old Jan 6, 2013 | 10:01 PM
SieGunso's Avatar
check your fluids
Old Jan 6, 2013 | 10:08 PM
Have check my brake, engine, and CVT fluids all are good.
Any other fluids to be taken care ?
Old Jan 6, 2013 | 10:48 PM
kgb4187's Avatar
Is it just once, when you first drive off after starting the car?
Old Jan 7, 2013 | 12:49 AM
It happens mostly when the car comes to a complete stop and move off. Not only when i first drive off after starting the car. But it seems to happen more when the car is cold. The sound lasted about less then a second.
Old Jan 7, 2013 | 01:22 AM
kgb4187's Avatar
How many miles on your car? Have the brakes been serviced? Check the rotors for grooves.
Old Jan 7, 2013 | 01:37 AM
63K miles on my car. Had only changed my brakes fluid. No servicing on rotor or capliers.Had only changes the brake pads. Had check the rotors for grooves, there is alittle grooves. How to consider whether the grooves are bad.
Old Jan 7, 2013 | 03:44 AM
jmsplitfyre's Avatar
This happens to me a lot specially in the winter. Check the brake rotor shields for some rocks/debris stuck in between. That may cause it.
Old Jan 7, 2013 | 05:30 AM
B Fit's Avatar
If you have the M/T it sounds like the throw out bearing may be starting to wear out or the clutch disk is worn down to the rivits.
Just a guess as I can't hear the sound myself ................................
Old Jan 7, 2013 | 09:35 AM
mkane's Avatar
This^^^^^^^^^^^^^^^^^^^^^
Old Jan 7, 2013 | 06:17 PM
jazzivtec's Avatar
is your car a/t? normally happens when you shift it from P to D? or to sports mode? but not happening during short stops, traffic, or when shifting from N to D?
i was told that its normal and hope it really is.
Old Jan 7, 2013 | 07:22 PM
Will check my brake rotors shield.
My car is A/T. It doesnt sound normal to me as before i went for my servicing at 61k miles i didnt have this this sound. It happens usually at R to D or during traffic stops.
Could a bad drive belt give this sound out ?
Old Jan 7, 2013 | 08:26 PM
jazzivtec's Avatar
mine is only 2 months old with 5,000 kms but already with that sound. couple of more friends is hearing the same and providing the same description
Old Jan 8, 2013 | 02:12 AM
Jazzivtec it doesnt sound correct to me as my vehicle has been on 100k KM with no sound and after a servicing this sound came.
I will bring it down to the servicing agent to double check for me soon.
Old Jan 8, 2013 | 01:05 PM
jazzivtec's Avatar
^ let us know the culprit and how its fixed. thanks
Old May 2, 2013 | 10:55 AM
Finally found out the problem for the sound it was the wrong drive belt used. After changing to the Honda OEM drive belt the car feels smooth no more grinding / gravel sound.
Old May 2, 2013 | 04:56 PM
13fit's Avatar
Did they do the fix for free? They should always use OEM parts on a vehicle less then 100k miles (160k kilometers)
Acid Jay
Jun 6, 2012 09:59 AM
SCBarren
Mar 29, 2011 09:55 AM
daweatherman
Aug 20, 2010 04:45 PM
Halcyon
Mar 15, 2010 11:04 PM
raton
Jan 16, 2009 01:07 PM
