17x7 +40 anyone running it :)!???
hi there i wanted to go 17in rims but wanted to know how it will look and i wanna run 215/45 tires im on buddy clubs so ride height not the issue i just dnt wanna pull fenders i rather roll the inside thats all
Originally Posted by Wafulz
(Post 1157764)
I have 17x7 +40 with 205/40 tires on it
you might have to roll/pull/trim the fenders if you plan on going lower on the BCs :) but very sure they fit lol... anything can fit! even 18x9.5 +0
Same exact specs I ran on my Momo's. I was running -2.5 degrees of camber and had to pull the front fenders when I sat at this height:
http://farm8.staticflickr.com/7119/7...803c74f3_z.jpg http://farm9.staticflickr.com/8006/7...c521557b_z.jpg http://farm9.staticflickr.com/8011/7...e87a5b2a_z.jpg (shameless plug - these are for sale) |
Thats a pretty tight offset bro, it looks pretty darn flush. :D
Originally Posted by FittedOnEm
(Post 1157879)
FittedOnEm whats ur spec:)
read some above..
(Post 1157879)
I'm bagged and running 17x7 +42 wheels with no camber or modified fenders. All wheels tuck just fine when I fully dump the car. 2mm isn't too much of a difference so I'd say you can get away with it without any fender modifications. Hope this helps!
I'm in the process of buying wheels too. Work 17x7 +42, but I'm trying to make sure they're gunna sit flush with my fenders and no rolling needed. I've seen some say I should be fine, they some say major rolling necessary. Anyone? :\
Originally Posted by MugenShelly
(Post 1166748)
I couldn't run 40mm offset on 17x7 wheels and 195/45 tires but just barely could with 195/40x17's. We had only one other who insisted on trying but couldn't either. You're much safer wth 45mm offset. |
A big part of this is that you are on coils. Since you will be able to control the amount of wheel travel (by setting more pre-load in the spring), you can set it up how you like. I would personally go with a 195/45 or 205/40 setup. On just springs, the wheels travel a bit further and rub a bit easier.
