Place to mount Scan or Ultra Gauge??
Old May 22, 2013 | 07:14 AM
over40pirate's Avatar
Has anyone found a good place to mount a Scan Gauge or Ultra Gauge, in their Fit?
I have a SC in my Tacoma, and if I don't move it to the Fit, I may get a UG, if I can figure out where to mount it.
I would rather not mount it on top of dash, or with a windshield mount.
Old May 22, 2013 | 09:05 AM
Forgot to say, I have a Fit Base, without Nav.
I also am not interested in mounting it by the small window, next to the windshield.
Old May 22, 2013 | 12:16 PM
Triskelion's Avatar
Here's mine---
http://imageshack.us/a/img546/103/1000143x.jpg
www.proclipusa.com
Old May 22, 2013 | 12:29 PM
Thanks for the pic. Not sure I want to block a/d vents. SW FL, and we use a/c all the time!
What brand is the dash pad? Carpet? Velor? or other? How do you like it? Does it get very hot parked in sun? The plastic dash must get up to around 150 degrees!
Thanks again
Old May 22, 2013 | 12:59 PM
Triskelion's Avatar
Thanks again
The dash vent is not blocked- the clip doesn't get in the way of air flow. Dash mat is Coverking bought through Costco web site- carpet, not velour. Three years old, still looks new, stops dust and glare.
Old May 22, 2013 | 04:26 PM
DaveFL's Avatar
SW Florida, don't let sun near it, if you are doing the ultragauge, they have a disclaimer in the fine print, sun could be a problem, mine the velcro released and it dropped to the carpeted floor, don't know what cracked the lens but ultragauge doesn't mind charging for shipping and rebuild.
Old May 22, 2013 | 04:49 PM
TPColgett's Avatar
Here's where mine is in my GD:
Not Ideal, but hides the pesky TPMS light
Old May 22, 2013 | 05:35 PM
MNfit's Avatar
^^^ That is where I mounted mine as well. It blocked that pesky TPMS Light but also din't block any important warning lights.
Attached Thumbnails Place to mount Scan or Ultra Gauge??-2012-02-07_14-11-28_795.jpg
Old May 22, 2013 | 06:23 PM
I was thinking of mounting mine there also, unless I decide to leave it in the Tacoma, and get an Ultra Gauge. UG is a lot taller, and wouldn't work there.
I'm leaning toward using the SG, and if I need it for code reading or a trip in the truck, just swap it back.
I think I can write down the setting for each vehicle, and reset, when I swap vehicles.
Thanks for the info.
Old May 22, 2013 | 10:11 PM
dayzeedawg's Avatar
I have mine mounted low in console in front of the shifter and cup holders. In the small cubby there. Cables are routed through the rear seams of console. It looks natural there. I have the scanguage II.
Old May 23, 2013 | 11:51 AM
Think I will mount it above the steering column. I look at a lot when driving to get mpg, as I drive, so down low wouldn't work for me. I mean texting and looking down while driving.... Just kidding!
Old May 23, 2013 | 01:48 PM
macbuddy's Avatar
I mounted mine above my Wink mirror, right next to my radar detector.
I flip down the visor to cover them when I leave the car.
Old May 23, 2013 | 02:10 PM
TPColgett's Avatar
HOW HAVE I NEVER SEEN THIS?!?!?
Next meet I have to check out your car again LOL
Old May 23, 2013 | 07:27 PM
macbuddy's Avatar
...because I have been flipping the visor down for the past 6 years!
Old May 24, 2013 | 05:18 PM
dayzeedawg's Avatar
Sorry the Fit is dirty.
I can easily take it out for use in another car.
Old May 5, 2014 | 06:30 PM
prhkgh's Avatar
I initially would put my scangauge in front of the center cupholders like the picture above, and held it in place with doublesided tape. But I had trouble resetting it when I'd gas up, and I like to leave it displaying miles to empty.
Since both front seat occupants have a cupholder on the edge of the dash, and another inside their door, I now just put the scangauge right in the two center cupholders, with nothing but gravity holding it. Easy to read, easy to pick up to change settings when I gas up. It rests atop the cable to it, that is just doubled back and forth under it, in the cupholders. Not elegant, not in the way, easy to read, easy to use.
Old May 21, 2014 | 01:48 PM
Fit Charlie's Avatar
I got their horizontal surface mount. It partially blocks the trip odometer, but if I move my head to the right a bit I can see all of it. It also blocks the tach past the redline. It's a great location for it.
gkitf16
May 22, 2016 12:04 PM
Oneoldphlaytis
Feb 16, 2016 04:39 PM
Grayfox
Sep 12, 2012 07:35 PM
hoteldalta
Jul 27, 2011 02:06 AM
lcsw1953
Dec 15, 2009 10:56 PM
