Acura ILX Rims on my Fit
Old Sep 23, 2013 | 01:05 AM
Cesfit's Avatar
Old Sep 23, 2013 | 01:26 AM
Cesfit's Avatar
More pics with the little brother too....
Old Sep 23, 2013 | 01:50 AM
BMW ALPINA's Avatar
Originally Posted by Cesfit
How do you modified the Fit 4 lug into 5 lug ?
Are you using the Kuo's garage conversion kit or you build your own ?
Thanks
Old Sep 23, 2013 | 02:17 AM
Cesfit's Avatar
by my own way.( my mechanic, not me)
Old Sep 23, 2013 | 02:24 AM
skatinemcee's Avatar
Whatttt???? How!!
Old Sep 23, 2013 | 02:25 AM
And what lip is that?
Old Sep 23, 2013 | 02:31 AM
BMW ALPINA's Avatar
Yes, how do you do that modification?
Do you use other Honda part?
Thanks
Old Sep 23, 2013 | 03:07 AM
Cesfit's Avatar
No, just bought 4 bolts and a set of wheels locks, them all olds parts of the car.
1. disassemble
2. the mechanic have a form guide to open the 5 hub assy holes and the disk holes too.
3. everything have to be milimetrical centered, if not u will have problems like have unbalanced tires but worse.
I will put some more pics in a few days about process.
About the lip, I recommend it i bought it on Amazon:
Amazon.com: EZ Lip Universal Front Bumper Spoiler and Protector 8.5 Feet: Automotive Amazon.com: EZ Lip Universal Front Bumper Spoiler and Protector 8.5 Feet: Automotive
Old Sep 23, 2013 | 09:53 AM
cjecpa's Avatar
I would be interested in this more wheel options.
Old Sep 23, 2013 | 10:08 AM
wow, that looks great, op! GJ!
Old Sep 24, 2013 | 01:19 PM
KJR50's Avatar
Looks like re-drilled/re-assembled with original Fit parts, look at the original lug holes in the brake disc. OP, any noticeable vibration issues?
Old Sep 24, 2013 | 01:32 PM
BMW ALPINA's Avatar
1. disassemble
The Disk Brake Rotor and Rear Drum Brake Cover (USDM) might be drilled without problem.
but this part right here:
The actual Hub were the wheel stud is, got to be from a new / different part.
Because there is no way you can re drilled the original 4x100 holes to install the new 5 wheel stud.
Kuo's Garage had made a conversion kit,
but I always think that a CR-Z 5 hub would bolt on to our Fit (have not compare the part side by side though),...
so your mechanic must either found another Honda with 5 stud hub that fit to our Honda Fit or he must machine/modify it to fit.
The question is,
Which car model did that 5 stud hub came from?
here is the Kuo's garage hub for reference so you can see there is no way to redrill that part,
because the stud had to be TIGHT, and re-drilling will have at least 2 holes overlap and will not allow the
stud to be TIGHT fit:
FRONT:
REAR:
Old Sep 24, 2013 | 01:47 PM
cjecpa's Avatar
There seem to be interest in this kit but I think people were having trouble finding someone to drill the rear drum to 5x114.3 and center bore to 64.1.
Old Sep 24, 2013 | 02:58 PM
Wanderer.'s Avatar
Quick research shows 5x114.3 Civic drums are almost exactly the same inner diameter as Fit's drums.
7.87 in. Civic
7.88 in. Fit
Service diameter is 7.91 for both apparently.
Just putting that out there.
Edit: Why would Kuo's garage make center bore 64.1? Is that a standard size for aftermarket wheels or something? That's nothing that couldn't be gotten around with a spacer anyway, but just wondering.
Old Sep 24, 2013 | 03:09 PM
zilla8's Avatar
Looks really good like they belong on the Fit.
Subbed for more info on fitment
Old Sep 24, 2013 | 03:24 PM
BMW ALPINA's Avatar
I am sure there are a lot of machine shops out there willing to drill the USDM Rear Drum to 5x114.3,
people just have to go directly to that shop and just said, I want this metal drum to be drilled to this configuration,
don't have to say anything about brake or something, just say you need for custom project,
this way the machine shop will not have any liability and will just do it.
(don't ask don't tell policy )
(actually it's not a problem in my case since I already have the JDM rear disk axle)...
but
I think the GENERAL problem is,
this Kuo's kit (TOTAL INSTALLED COST) is not that cheap for Honda Fit user demography/market segment.
because not only the price of the kits are near $600,
but after that,
you still have to change your wheel and tire too.
(not to mention the spare tire no longer work and need to change
to 5 lug spare tire too).
Which mean the minimum cost for this kit INSTALLED and ready to use
(with either new/used wheel/tire and spare tire) would
cost from as low as $1,000 (if you can find a used wheel and tire for $400 which should be in very bad condition),
up to $2,000 for cheap new wheel and tire and spare tire package,
to the sky is the limit (if you want exotic wheel and high performance tire)...
For me, my main personal problem with this Kuo's kit is,
First, I already bought my wheel and tire for 4x100 pcd
and
I would be reluctant to spent more money to buy a new set of wheel and tire,
I just wish I knew about this kit before I bought my wheel...
Second,
I also worry that if someday the BEARING that came with the Kuo's kit need to be replaced, will I be able to find replacement bearing?
If Kuo's garage still in business at that time (probably 5 years from today),
then I will not have problem, but what if they are no longer in business...
That is why I am interested in finding an OEM replacement hub that can either bolt on or modified by myself, so I knew which OEM Honda bearing I need to buy in case I need a replacement bearing in the future...
after I knew how to make this 5 lug kit on my own using Honda's OEM parts,
then I would think whether I actually want to do this conversion, since that mean I had to buy a new set of wheel and tire,...
I am sure many other prospective buyer of this kit are having second thoughts like what I had above...
7.87 in. Civic
7.88 in. Fit
After quick search looks like most Honda with 5x114.3 PCD (5 lugs),
have center bore of 64.1mm.
This can only means that most likely Kuo's find other Honda 5 lugs hub that can be machined (or even direct bolt on) for our Honda Fit !
That also mean, most OEM and aftermarket wheel for Honda with 5 lugs are
using the 64.1mm center bore (and not our standard smaller center bore)
Old Sep 24, 2013 | 03:40 PM
Wanderer.'s Avatar
Good catch my man I didn't even notice that
Too bad the Fit's hubs are welded on instead of bolt on like the Civic. Could have been a complete OEM 5 lug option. Damn you Honda lol
Old Sep 27, 2013 | 02:30 PM
Wafulz's Avatar
i like ur redrill rotors reminds me of my micky mouse ones that work great 12in s2k
Old Sep 27, 2013 | 10:00 PM
True Adrian's Avatar
doesn't the new EV Fit have 5 lugs? wouldn't that be plug and play?
Old Sep 27, 2013 | 10:29 PM
Cesfit's Avatar
Calm ff, be patients guys i will show more pics next week cos i have to fix something and my english is not good talking about mechanism and car parts.
However i love how the car look with those rims and options are more on 5 lugs..
