Another FUSE question? Fog lights - GE8 Sport Model
Hello guys,
I'll receive my conversion Kit HID 35W - H11 soon, I found some posts recommending to upgrade the FUSE for the fog lights, I would greatly appreciate if someone of you knows where is the fuse for fog lights and would be quite useful too if someone give us the FUSE MAP, i tried to read the map in the car but is very confusing. Thanks in advance, Luis ----------------------------------- 2013 HONDA FIT Sport AT - Cnd Mkt |
Personally, I wouldn't put HID in fogs, but whatever.
If the kit uses a relay, you won't need to "beef up" the fuse. I would recommend a relay, if you don't have it. Because the fuse isn't the only thing at risk when you put something that draws more power at any given moment... the entire wiring is susceptible to it. The relay avoids that. That being said... it's your decision on what to do. Fuse for fog is #9 (bottom small fuse on left most column) |
Thanks for the information, finally I changed my Fog lights Bulbs for the HID 6000K and for the people who have the same question --*» where is the fog lights fuse in a HONDA FIT GE8?:
RED ARROW: FUSE N. 09 ORANGE ARROW: FUSE PULLER (JUST PULL OUT) http://s2.postimg.org/6o79nqns9/fuse_luis.png Luis |
