What do we need to change once reached 100,000 km?
Old May 21, 2014 | 01:27 AM
wackyflik's Avatar
My car has clocked 125,000km recently. I did not send my car to Honda service center anymore. Basically, what do I need to replace at this moment beside oil filter, engine oil, gearbox oil? I have heard somewhere I have to change fuel strainer. Is it true? My gearbox oil changes at every 20,000 km and I am using Ultra ATF-DW1. My engine oil uses Blitz Racing Oil. And I am using Js Racing air filter.
Old May 21, 2014 | 01:57 AM
BrianKearsey's Avatar
According to the Maintenance Schedule I have, it says "Replace fuel filter every 45,000 km or 3 years, if the fuel the customer
uses is suspected to be contaminated
." this if for the GE, not sure about the GD.
Honda South Africa only replaces it at 105000km though.
Old May 21, 2014 | 02:28 AM
13fit's Avatar
At that mileage, I would change the thermostatm waterpump, and timing chain tensioners.
timing chain itself is good for a LONG time
Old May 21, 2014 | 02:52 AM
wackyflik's Avatar
No offense bro, what is actually thermostat water pump? No idea on that part but I do know the thermostat. Thinking to change to low temp thermostat.
Old May 21, 2014 | 04:07 AM
13fit's Avatar
it was supposed to say thermostat AND waterpump lol
Lower temp wont help a whole lot, but the thermostat gasket maatches part numbers for pretty much all of honda's FWD 4 cylinders back to 5th gen civic at least
so you have 140-190 degree range to choose from.
stock is 170. lowest I would try is 160
FitsMePerfect
Sep 21, 2011 03:55 PM
SmartSizer
Mar 12, 2008 02:15 PM
kimo
Jan 24, 2008 05:38 PM
ludexr
Sep 17, 2006 10:13 AM
coldstorage5
May 4, 2006 07:21 AM
