PN for Center cap for 15" steelies?
Old Jun 22, 2014 | 08:35 AM
599Ed's Avatar
I have a 2013 base Fit. The first thing I did when I got it was to take off the ugly stock hub caps. I have done quite a bit of searching for the correct part number for the chrome Honda center caps that will fit on the stock 15 inch steel rims. I think they look good with chrome lug nuts. No luck. Any help would be appreciated. I don't want to waist money on the wrong part. Thanks in advance!
Old Jun 23, 2014 | 05:04 AM
Black3sr's Avatar
Here you go.
https://www.fitfreak.net/forums/gene...er-caps-3.html
A pic of my winter setup using these caps and my Sp
ort nuts.
Old Jun 23, 2014 | 07:34 AM
599Ed's Avatar
Thanks for your help Black3sr. I am actually looking for the OE Honda caps with the H on them. I think they fit the rims for some older Civics.
Old Jun 23, 2014 | 09:36 AM
Black3sr's Avatar
I went the Honda caps first as well. Finally found some. First winter was ok but next Year two of them fell off. They were pricey as well.
If you want H logo you can find vinyl ones to put on the silver caps.
Old Jun 23, 2014 | 11:16 AM
xxryu139xx's Avatar
i agree with blackser. those oem caps from old school hondas are very pricey. best bet is to go with the chrome caps like me and blackser. or hit up your local junkyard and see if u can find some decent ones. u can find used ones ebay but they are like 20-50 bucks each.
Old Jun 23, 2014 | 04:42 PM
msbxiv's Avatar
Bernardi seems to have them--part number is 44732-SB2-000. They're $25.13 each. These came up for a 1991 Civic DX wagon (where mine came from, and confirmed fitment).
Old Jun 24, 2014 | 12:38 PM
gkitf16's Avatar
Nice look to go with those. If you're sticking with open-face black steelies, the paint on them can be a bit thin in places. I did mine on both sides with Rustoleum gloss black, after thoroughly cleaning brake dust etc off using de-glossing cleaner (Home Depot paint dept $6) and rags. 2 coats of paint later and some new chrome lugs (be sure to use ball seat taper lugs for steelies) and they look better than factory, even under the pie plates. Plus any brake dust doesn't stick much and rinses away easily at bath time.
what2016
Oct 29, 2016 10:37 PM
nikita
Oct 7, 2014 06:28 AM
TheLaughingMan
Jan 27, 2014 10:48 PM
Edison Carasio
Dec 19, 2013 09:15 AM
g35man04
Sep 21, 2009 11:24 AM
