12 Base: tailgate will not lock
Old Oct 25, 2014 | 02:49 PM
msoques's Avatar
2012 Base model: tailgate will not lock either with fob or manually (from driver's side switches). There is no key port in the tailgate.
The open/close sensor in the tailgate apparently works because the alarm will sound if I lift the tailgate and the door open indicator lights up in the instrument cluster.
Any ideas on how to diagnose this issue? Many thanks in advance.
Old Oct 25, 2014 | 06:06 PM
Goobers's Avatar
I think due to rusting in the handle, my hatch HANDLE doesn't always release back to the correct position.
Check to see if the handle moves freely... and try pushing it to where it should be and then see if the hatch stays closed/locked.
Old Oct 26, 2014 | 02:06 PM
hogwylde's Avatar
Why even worry about it on a '12? It's still under warranty so take it back to the dealership.
Old Oct 26, 2014 | 05:18 PM
Goobers's Avatar
it could be out of warranty if driven out of the mileage limit (as I did in 2011, barely 15 months after buying my 2010 Fit).
alfagirl56
Apr 14, 2023 12:57 PM
jond63
Sep 13, 2016 06:13 PM
LVFit
Jul 7, 2016 08:56 PM
Adam Zier-Vogel
Jan 12, 2016 09:46 AM
deevergote
Jan 2, 2016 08:55 PM
