Grinding Sound at Start up?
Greetings everyone. I am new to the forum, and I had a question to ask regarding the subject line about. My vehicle is an 08 6 speed MT Fit with 106,000 miles.
At cold start up, the vehicle makes a loud grinding noise for about half a second. Oddly, the vehicle doesn't make the noise until it is cold again, but this is a broad statement in itself. From what I have been experiencing, the sweet spot is about 8-10 hours. If I start the car again within the 8-10 hour period, there is no sound at all and the vehicle starts up normally. If I let the vehicle sit for over 10~ hours, the sounds happens again at start up. Does anyone know what is causing this issue? Is this a common problem on earlier fits? |
My guess would be the antilock brake system priming itself. If so, it's perfectly normal and nothing to be worried about. It may be more common as the car ages due to (expected) wear in the pumps and valves making up the ABS system.
Originally Posted by DrewE
(Post 1276731)
Originally Posted by jtm893
(Post 1277098)
I'll look into this. The only other thing that makes sense is the starter going out. Oddly, I can't find a thread about it on the forums, but there are many threads on other Honda vehicle forums that have exhibit similar symptoms.
I had a starter wear out on one of my cars. In that case, it was the overrun clutch (a one-way clutch lets the engine turn faster than the starter motor when it starts running) that would not grip when it should, so the starter motor itself would whirr away but the engine wouldn't crank at all. There are other ways for them to fail, of course, and clicking/buzzing/grinding noises are possible if the pinion isn't engaging the flywheel properly for whatever reason. |
Neither started not ABS? sound reasonable at all.
You either have a belt slipping, or your engine is suffering insufficient oil lubrication/pressure at start up. Either way is not good. Make sure your oil is fresh and at the right level. Listen for the source of the noise. Go from there. Nothing normal about the noise at start up. P.S. there could really be dozens of reasons, but it's pointless to try to diagnose over the internet (put a video if you want more feedback). Water pump and alternator would also be suspected until ruled out. Good luck. |
[QUOTE=jtm893;1276675]Greetings everyone. I am new to the forum, and I had a question to ask regarding the subject line about. My vehicle is an 08 6 speed MT Fit with 106,000 miles.
I bet the problem is with your 6th gear... it shouldn't be there:eek3: |
lol nice catch
same here
Has been happening to me towards the end of last winter, when away when it got warmer, and has been happening every morning since the temps in NJ have dropped below 60 overnight..
when it happens the engine turns over quick, so I believe it's the starter... |
2 Attachment(s)
(Post 1276675)
At cold start up, the vehicle makes a loud grinding noise for about half a second. Oddly, the vehicle doesn't make the noise until it is cold again, but this is a broad statement in itself. From what I have been experiencing, the sweet spot is about 8-10 hours. If I start the car again within the 8-10 hour period, there is no sound at all and the vehicle starts up normally. If I let the vehicle sit for over 10~ hours, the sounds happens again at start up. Does anyone know what is causing this issue? Is this a common problem on earlier fits? https://www.fitfreak.net/forums/2nd-...ml#post1330745 |
(Post 1276675)
At cold start up, the vehicle makes a loud grinding noise for about half a second. Oddly, the vehicle doesn't make the noise until it is cold again, but this is a broad statement in itself. From what I have been experiencing, the sweet spot is about 8-10 hours.? |
I have an 09 Fit and I'm noticing this too... what's the root cause and fix, do we know? my extended warranty just expired like a month or two ago :(
Ugh...sounds a bit like a dry start. My wife's 2004 Corolla also does this when it is cold.
Check the cylinder compression and perform a leak down test. Check the inside of the cylinders for any signs of carbon build up. Check the spark plugs. Make sure the oil is sufficient in level and condition, and the factory specified filter is used.
Check for abnormal sound while operating both cold and hot using stethoscope and by doing a test drive. Check the timing. If sounds persist, remove the valve cover and visually inspect the valve train and the camshaft. Make sure the valve clearances are within spec. Next would be the timing chain wear and tensioner operation inspection. Then more... Good luck. |
My 2010 does this every morning during the cold months. During Summer it never happens. Sounds like the starter to me. I can avoid the grinding noise by doing a quick key turn on and off 2-3 times; just enough to turn the starter, but not long enough to let it start. On the 3rd try, I let it start, and there's usually no grinding noise.
My 2008 Fit Sport started doing this, and my 2010 Fit Sport that I just bought on Thursday did it as well. Only on cold mornings. All signs point to the VTC Actuator.
My 13' Sport made the same sound couple of winters ago. Haven't heard this since then... :confused:
Originally Posted by Rampo
(Post 1384300)
So we're thinking its your starter then? starters got its little actuator gear guy that pops out to spin the flywheel or flexplate. an issue there would explain it occurring at start up and also being short term.
If youre curious you could try putting some gear marking compound on the starter gear or the flex plate and cranking the engine. The ac delco brand stuff is a bright yellow thatd make it real obvious if the gears are making good contact |
Yeah it's a sticky engagement mechanism or solenoid. Mine started making the noise last winter (09 with 130K at the time).
Replacing the solenoid and lubricating the mechanism would be the solution, but I think it's easier and better (maybe about the same cost) to replace the starter. I found a rebuilt nippon denso starter on Amazon for not too much, but I got lazy and never installed it. It stopped making the noise after it warmed up a bit outside. It's made the noise a few times so far this winter. When it becomes more frequent I'll swap the starter. The shop manual calls for removal of the intake manifold to gain access to the starter. Some have finessed its replacement without doing this. I bought a set of manifold gaskets just in case. |
Probably bearing on belt tensioner..that's what mine was.
