Any help on this immobiliser warning sign (LINK)
Old Mar 27, 2015 | 12:23 PM
Lydon Camilleri's Avatar
my honda fit is 2012 keyless entry smart key.
i tried to switch it off with (computer) but still came up, i have nothing wrong all is good, i tried to remove the battery and replace it again, but still, any another way to switch off the immobiliser key from the dash..?
thanks for your time again
Old Mar 27, 2015 | 06:32 PM
hogwylde's Avatar
Does the car still operate correctly? Can you drive it?
Old Mar 27, 2015 | 07:04 PM
Yes its just drive normally everything is perfect apart from that caution sign..
Old Mar 27, 2015 | 07:22 PM
hogwylde's Avatar
Do you happen to have a second key on you (or keychain) or near you when stating the car? Is this a new key you are using?
Old Mar 27, 2015 | 07:50 PM
No .. no keys near or similar. But someone from honda agent/sales/mechanic told me that this cas had an accident which the left mirror wasn't working properly. and they rold me the mirror has sensors in it. Does it mean something?
Old Mar 27, 2015 | 07:51 PM
hogwylde's Avatar
It doesn't make sense to me - but who am I?
I am continuing to look to see if I can help you at all.
Old Mar 27, 2015 | 08:03 PM
hogwylde's Avatar
Do you have "your own set of keys". IOW, do you have a SO that has his/her own key to your car? Put your key in the house and try using your partner's.
I know. Sounds crazy. Apparently the keys are delicate and Honda warns about dropping them.
Old Mar 27, 2015 | 08:31 PM
hogwylde's Avatar
Disconnect your battery for 30 minutes then reattach.
Old Mar 27, 2015 | 08:46 PM
hogwylde's Avatar
Am hoping this helps you my friend.
Immobilizer System Troubleshooting
Old Mar 28, 2015 | 09:56 AM
specboy's Avatar
It would not surprise me if the Honda Dealer was right on the sensor in the mirror. If you have the keyless entry with touch to unlock on the door, it may be that the system is missing a sensor (which could be very likely located in the mirrors as that would be an easy place to run wires/sensors to). You said everything is working properly but does your Fit have the push button to unlock feature on the door? If so, do you use it? (and does it work?) - many people still use the fob to unlock remotely even though touch sensors/buttons are installed - it's just usually a personal preference.
~SB
Old Mar 28, 2015 | 01:05 PM
dont have any push buttons to entry the door just the key FOB only lock and unlock button on the smart key, the smart key it has the key in it. but i will try to disconnect and connect the battery as you told me guys, fingers crossed, about the sensors in the mirror for me doesnt make any sense but anyways thanks for your time
Old Mar 31, 2015 | 05:31 AM
Specboy are you online?? yes i do have the feature key less entry with touch on the door, i just removed the battery and i waited 35mins, i plug it again, after that yeah i was so happy kinda the warning caution sign wasn't there, was like a big smile, after that i tried to use the feature from the door was working, then i switched off the ignition and turned it on again i did it several times but here it goes again the warning caution sign on the dash instrumental cluster appear, could be the sensor what you told me, because when i tried to use the feature wasn't working with the warning sign.....
SilverEX15
Aug 14, 2018 02:01 PM
Kelvin Yap
Mar 21, 2016 01:19 PM
Kiwifit
Nov 8, 2014 12:03 AM
cwapface
Apr 17, 2013 08:52 AM
FondaFit
Sep 25, 2006 11:18 PM
