Fuse Box Location
Hi all, I'm having A/C problems and I'm looking for the under hood fuse box. I've only found the under the driver's side dashboard fuse box location. Under the hood, I've only found the fuses on the positive side of the battery and 3 other fuses under the battery. Can someone give me a better idea as to it's exact location? Yes I've used the search button and I've tried searching online but no luck. Thanks.
So what are you looking for? There are only two boxes. #10 fuse is for the A/C switch and #29 for the light on the switch.
I was looking for a fuse box that had more than 3 fuses in it under the hood. The smaller box only had 3 fuses or maybe relays and no labels which is under the battery. The positive terminal of the battery had other fuses but isn't what I was looking for. Basically, I'm looking for a fuse box that looks like the one by the drivers side lower dashboard location but the one under the hood if there is even one.
So what are you looking for? Another fuse box? If so why? I thought your problem was the A/C.
The Owner's Manual will tell you exactly where both fuse boxes are. It will even give you a diagram of said fuse boxes.
