Ticking sound please help
Old Feb 4, 2018 | 03:38 PM
GAFIT's Avatar
Ditto the above, but will add that $400 isn't unreasonable for having the job done. I would just ask for them to include spark plug change while there. It probably adds 5 minutes to the valve adjustment job.
Old Feb 6, 2018 | 09:29 AM
Rigaudon's Avatar
Thanks for the feedback. I was thinking the same thing, have the dealer do the valves and plugs at the same time. I'll also include the drive belt change. My stepson, (I originally bought the car for him to commute to UCONN), has an internship in Fairbanks Alaska this summer. The Fit is currently in Connecticut so I'll be driving to Chicago to leave it with him and then he'll drive from Chicago to Fairbanks. Its got approx 85,000 miles so I want to get some things done that will be coming up anyway prior to the trip. My preference is no spark plug blowouts while in the middle of nowhere on the AlCan highway!
Old Oct 18, 2019 | 01:38 PM
monkeydave's Avatar
does the noise go away when the engine is warm ? and does it start right away or after a few mins
i have the same noise on my 2018 jazz
i only have 5000 and noticed it after the first oil change service at honda
the weather is colder now but the oil is at the max mark
Old Oct 21, 2019 | 01:40 PM
claycolvin's Avatar
Noise
That motor sounds fine to me. Time to adjust the valves and make it run smoother. Not a real problem yet, but adjust those valves. Try some Rislone in the oil, its an additive that quiets old engines and makes them run better. It should run really well with the valves adjusted and a bit of Rislone.
Best of luck, Clay
Old Oct 23, 2019 | 02:08 AM
dwtaylorpdx's Avatar
I can do the plugs, and the valve adjust in about n hour and a half,
400 is about 3 hours labor... thats ugly math..
Nearly eveyr town has a indy that does honda.. Get to know them..
Old Dec 4, 2019 | 08:43 AM
victorampereira@gmail.com's Avatar
Someone comented that noise from the thread starter could be an exhaust leak?
Does exhaust leak sound metalic? That's insteresting to know, because that leads me to think exhaust leak could be something to check on my car for the metalic issue i am hearing. That could be the issue.
Old Dec 9, 2019 | 06:18 AM
spike55_bmw's Avatar
To me, it wouldn't be 'metallic'. In my past experiences, I would either here 'whistling' / 'puffing' if the problem was nearer the back of the car. If nearer the engine, I would hear more of the combustion explosion / un-muffled detonation sound.
My '11 Sport AT, has loose valve noise that slowly goes away as the engine warms up (takes longer when starting out in winter temps). There seems to be some other 'clicking' sounds coming from the EGR (exhaust gas recirc) device mounted on passenger side in front of the cylinder head. Maybe remove and clean. These were sooty on my some previous cars.
Henus
Dec 20, 2018 02:17 PM
Chavo
Aug 10, 2016 12:08 PM
frank438
Jul 12, 2016 11:14 AM
ricohman
May 22, 2011 09:34 PM
Kwonye
Jul 12, 2010 07:11 AM
