Again, I'm curious why everyone wants to change coil packs when they are still working. Easy to change later it here's a code.
Originally Posted by spike55_bmw
(Post 1441121)
When I changed my plugs at 134k, it was already long after the maintenance minder code for it came and went. Unless you're talking about waiting for a DTC to pop... now, that would be silly. |
To me, a coil pack can easily / cheaply be gotten and be installed in less than 60 mins when changing all 4. I'm just skeptical about a display telling me what to do that is simply based on miles driven not matter how easy / hard / rain / desert / etc. I'm more willing to wait for the code / engine missing (1 cyl at a time - what are the chances multiple coil packs fail all at once and leave you sitting?).
That said, I'll get new tires (deep tread) prior to winter (Pennsylvania) even though my tires would be good / pass the state's annual safety inspections for another 10,000 miles in Florida / Texas. I just approach this differently. No right or wrong implied by me. |
(Post 1441128)
I can guarantee that I can reach in on the passenger side with my left hand / arm with a 10mm socket on wrench for the coil pack bolts and replace each coil pack in less than 60 mins. If you're not fussy about torque specs, changing the spark plugs at the same time doesn't add much more time.
I agree it would take hours, if you are going to remove the windshield wipers, the plastic cowling, the full airbox, so you can access the rear of the engine and use a torque wrench on each plug, and them put it all back together. I'm done with that process, tried it and the plugs worked loose again anyway. I did the 'left-arm reach in' and put blue threadlocker on each plug and it has held up for 30,000+ miles. I guess I'm one of the luck ones since that process has worked so well for me. |
