Looking for Honda TCS codes
I've looked and looked, but I'm coming up empty.
Does anyone know where I can find TCS codes? They are from a 2001 Acura CL, and the codes are: 31, 34 and 61. Thanks. |
Code info from an Accord v6 same year:
Code 61 ignition voltage....may or may not be related to the current issue (could be a history code)....chart just says to erase the code then drive it above 10 MPH and see if code resets.... but you probably have to solve the other codes first 31 front right inlet solenoid 34 front left outlet solenoid spec inlet solenoids 8-10 ohms outlet solenoids 3-5 ohms Two different solenoid codes at the same time makes me wonder if you might have a wiring problem....got rodents? |
Thanks so much.
Do you know where I can find all the TCS codes online? Not sure about rodents. This car was inherited with issues! |
Do you know where I can find all the TCS codes online? Try autozone/Alldata or Mitchell on demand Google honda abs codes or acura abs codes? (TCS is part of the ABS system) |
Actually, the ABS light is flashing its own code (13: wheel sensor: open/short to body; ground/short to power LF)
The TCS light is flashing those other three codes. |
13= left front (left is drivers side) WSS
