Back up camera
Does anyone make a back up camera for a 2013 Fit Base?
I bought this one and it fit perfectly.
https://www.ebay.com/itm/For-Honda-C...item33d6850933 I wired it to an aftermarkey JVC KW-M730BT. I tapped into the reverse lights. You have to take off the rear hatch cover to install and then route the wires through the rubber wire connector from the hatch into the car which was a challenge. I installed it late 2017 and it's been working fine since. |
some info here..
https://www.fitfreak.net/forums/2nd-...-question.html |
Originally Posted by Rigaudon
(Post 1411875)
https://www.ebay.com/itm/For-Honda-C...item33d6850933 I wired it to an aftermarkey JVC KW-M730BT. I tapped into the reverse lights. You have to take off the rear hatch cover to install and then route the wires through the rubber wire connector from the hatch into the car which was a challenge. I installed it late 2017 and it's been working fine since. Was it worth it to you? Im more curious in the quality of the camera.. is it good? |
What head unit are you going to hook your camera up to?
There are a lot of cheap options on AliExpress, possibly eBay/Amazon too. I bought this camera off of AliExpress, I haven't installed it yet, though. I hope to do so this weekend. https://cimg2.ibsrv.net/gimg/www.fit...c332cb5e96.jpg I currently have the Auto-Vox X1 Pro rearview mirror installed on my car and am using that camera. Sorry no pics of this, I may do a post about this in the future though. The camera is installed using one of the license plate screws. |
https://www.amazon.com/gp/aw/d/B06X97YNHS?psc=1&ref=yo_pop_mb_pd_title
bought this one has night vision l e.d that turn on |
Originally Posted by sean.haynes
(Post 1412050)
Im pretty sure I saw a youtube video of something doing this same install.. the fit is so small I have no problem parking it. However, after upgrading to a double din and now having the option, I am tempted..
Was it worth it to you? Im more curious in the quality of the camera.. is it good? As a side note, we have two 2012 Base Fits and my stepson (age 26) said "do not add a backup camera to his Fit". He is old school (at 26), and finds the backup camera distracting. I like it and find it works well. The camera quality is surprisngly decent. Not high def, but clear enough. |
https://amzn.to/2QRE4XH This one works really well for me.
Originally Posted by Nick Farley
(Post 1413578)
i assumed they only turned on when in reverse and left one side of the license plate dim the rest of the time? |
(Post 1411875)
Sorry to bring up an old thread but do any of you have pics of what your reverse camera looks like installed? Specifically the ones that have the integrated camera to the clear reverse light housing. How low does it protrude and does it have a decent angle? I cant find any pics online of this style actually installed. Thanks. |
Originally Posted by jthai
(Post 1425112)
Sorry to bring up an old thread but do any of you have pics of what your reverse camera looks like installed? Specifically the ones that have the integrated camera to the clear reverse light housing. How low does it protrude and does it have a decent angle? I cant find any pics online of this style actually installed. Thanks. china and is really terrible quality. I’ve thought about buying a new high quality one and trying to figure out how to install it. Photos below. https://cimg4.ibsrv.net/gimg/www.fit...7c28c30ce.jpeg https://cimg5.ibsrv.net/gimg/www.fit...43fb90dc5.jpeg https://cimg8.ibsrv.net/gimg/www.fit...7560578c5.jpeg |
Nice! Thanks for the pics Bucho. There’s a camera on Amazon by company called Navinio that I’m thinking of buying. Does your setup change the light pattern of the parking lights when on at night? What I mean is do the two rear lights still look uniform? |
Re-revivng a thread that was just revived. Sorry guys!
anyone have any guides on routing the cables? Also as usual, I intend to tap into the reverse light power. any recommendations? Thanks! |
Originally Posted by IfChris_ThenFit
(Post 1425390)
Originally Posted by marmaladedad
(Post 1425394)
I routed mine underneath the door sills, from the rear of the car to the front. There is just barely enough cable (in my case) to do so. I may try running it through the headliner from rear to front this weekend to see if it does not clean up the bits of exposed cable. As for connecting to the rear light wires, I used some wiring T-taps to simplify the process (instead of stripping, soldering, and heat shrink). Some may balk at the usage of these, but it is up to you. I have had no problems with them so far.
(Post 1425441)
Any reccomendations on what exactly to get? wire gague? Thanks! :D
I did not have to use any extra wiring. A wiring harness is included that you need to connect to your existing backup lights, whether it be by cutting/soldering or some wire-nuts or taps. |
Installed my back up camera and I am happy with how it looks (OEM like) and clear output from my HU.
https://cimg1.ibsrv.net/gimg/www.fit...22b5d92fb6.png |
How it looks like installed on my Honda Jazz/Fit GE
https://cimg7.ibsrv.net/gimg/www.fit...b95a24a54.jpeg https://cimg8.ibsrv.net/gimg/www.fit...46c1b6efb.jpeg https://cimg9.ibsrv.net/gimg/www.fit...68d61d98a.jpeg https://cimg0.ibsrv.net/gimg/www.fit...e5ac1d591.jpeg https://cimg1.ibsrv.net/gimg/www.fit...8fca849d1.jpeg |
I like the integration of the camera. Looks good.
