Misfire after PLUG SWAP? valve adjustment?
Old Oct 22, 2018 | 06:48 AM
spike55_bmw's Avatar
Curious why the coil packs were changed too. How many miles on coil packs? How many miles on the plugs? Were you getting a CEL? Did you only change the plugs first and still had problems?
Old Oct 23, 2018 | 05:55 PM
JerrySFL's Avatar
Going through the same thing replaced, the plugs with new NGK’s and all coil packs with new Hitachi’s runs better , using a Autel 808 Pro to monitor live data misfire; but still have ramdom misfires on 2 and 3 ; swapped plugs and coils around , same result, looks like I will be pulling the intake and cylinder head cover and adjusted the valves. �� Just finished pulling the oil pan to reseal it, had a leak right behind the crank pulley.
Old Oct 23, 2018 | 07:06 PM
GAFIT's Avatar
Good luck Jerry!
I'm sure that a valve adjustment will fix the misfire. It's sad how few Fit's get the required service. GE maintenance minder triggers service "4" somewhere around 90-100k miles, but it's always ignored. Service 4 says to check valve clearance.
Old Nov 3, 2018 | 06:54 AM
RainierV, are you still getting misfire codes? Did you get the valve adjustment?
Lucas1976
Jul 5, 2018 12:01 AM
fittenmittens
Sep 2, 2016 06:40 PM
lukeskywalker1
Feb 23, 2014 05:42 AM
SteveZ
Mar 5, 2012 09:36 PM
hogwylde
Aug 14, 2011 07:35 PM
