29MPG Highway :(
Hi All.
I just started a new job so I bought a 2014 5MT (Canada). Of course it is now winter and our pumps are on different gas chemistry which decreases MPG overall (noticed previously in my motorcycle). My r/t to work and back is 200KM, and I do this two days a week, other three days a week is much shorter commute. It is all highway, and generally set cruise control to 112KPH, or 70MPH (speed limit is 110KMH... I'm such a badass). I am consistently getting 29MPG. I've yet to break 30. This means for each trip to work I am using about half a tank of gas. Things I've done to try to improve mileage: Cruise control set as soon as I get on the highway, which is only about a KM from my house and work. Tires inflated to 36PSI No AC (winter, brrr) No warm up, just get in and go Just me (180lbs) in the car with my work bag. No junk in the back other than a snow brush. NO CODES SHOWN. NO CEL. Things that I plan to do: Replace intake filter Idle Learn Procedure Clean MAF with MAF cleaner Things out of my control that might be what are making it worse: Winter grade gasoline Winter tires I'm interested to see how things change come summer... |
when was the last time, front end alignment (toe) was checked?
Is that 29 mpg calculated with the car computer? Have you checked the mpg via the car while on the highway with the trip odometer reset so that it resets the calculator?
Short commutes and city driving really kill the mpg. You could average 35 highway get 25 around town and end up averaging 30. |
Cleaning throttle body might improve things also but seem to be a bit of work on the FIT.
In some cars running the front defroster engages the a/c compressor to reduce condensation. You could pull in outside dry air to help there. I suppose fresh transmission oil couldn't hurt. |
Our Fits don't fare well in the cold. I can only imagine cold in Canadian standards.
How are your plugs looking? |
https://cimg4.ibsrv.net/gimg/www.fit...1a6c436ef5.jpg
https://cimg5.ibsrv.net/gimg/www.fit...1e0ae0bc4c.jpg I'm running 205/50-16 tires on 16x7 wheels, significantly reduced highway miles (better MPGs) to work, increase local miles (worse MPGs), inching my way to a solid lifetime average of 30 MPG at 73,000+ miles. Also note, that "on average" the dash MPG meter and the hand calculated MPG do closely track one another but individual tank fill ups can produce deltas of 1-4 MPG. Disregard the IRS calcs, which can change annually. I was just looking at reimbursements on trips but interesting to note what IRS considers the cost to drive, insurance, maintenance, etc per mile and life-time of ownership. ***Please note that the "as of date" should be 2019.01.02 **** |
https://cimg5.ibsrv.net/gimg/www.fit...8d17affca1.jpg
Correct "as of" date / 2019 |
Low rolling resistant tires will help. Not sure how much. I noticed an improvement when I changed tires to Michelin Energy (maybe 1-2mpg) over the factory all-season Pirellis. I think snow tires at all 4 corners is the culprit. That and 70/115 MPH/KPH.
On long trips I can get 35MPG on summer LRR tires driving 70MPH with light wind with the A/C on. My daily drive on Atlanta freeways averaging about 60MPH and some city driving is about 31MPG (no A/C) and 29MPG summer (with A/C). I've had tanks of summer driving with A/C, mostly city, that got as low as 26MPG. If someone put heavier oil than 0W20 synthetic in, that could be a source of lower MPG. Maybe 1 MPG. Don't expect a new air filter or cleaning the MAF to help. Modern electronic fuel injection prevents an inefficient fuel/air mix from occurring. I wouldn't touch the MAF. A clean air-filter if the old one is seriously dirty may improve power slightly as it allows a small amount of additional air at WOT. A dirty air filter doesn't worsen MPG as the fuel injection correctly meters fuel according to the amount of air flowing past the MAF. Any throttle less than wide-open restricts airflow a lot more than the filter. As the MAF ages, the feedback provided by O2 sensors adjusts the mixture so it stays correct. The other problem is people inflate the performance of these cars by hypermiling or just wishful thinking. |
Blocky winter tires and winter gas will hurt mileage so you can't do much about that. As Steve244 notes, your mileage does not seem terrible.
Every several years, we like to clean the intake systems of our cars. After they typically idle quieter and smoother. Gas mileage & drivability usually improve, but we do a lot of other maintenance at the same time so can't attribute improvement to this. My brother just purchased a Fit so don't know if these typical maintenance items are relevant for Hondas. Our generic intake/exhaust maintenance: - replace air filter. Make sure air box and intake hoses are perfectly closed and sealed - clean MAF (only with special MAF cleaner, don't touch MAF internals) - clean throttle body. these can get really dirty fast (study forum tips regarding lubrication. Some people recommended removing FIT TB for cleaning) - look for vacuum leaks (very important, you can listen and do a smoke test) - Clean EGR valve - passages - Remove and check PCV valve/gasket A few other thoughts: - Check spark plugs for color, gunk, wear, etc. for overall state of engine. - You might also want to run a few tanks of premium fuel from a major firm, not local unbranded fuel. That will run some of the expensive cleaners through fuel system. - If you car has higher mileage, your valves may need adjusting. Is the Fit 30k 60k 100k mile recommended? - Sometimes running a fully warmed up engine GENTLY at say 5k RPM for a few miles will help clean intake valves. Not sure that is the case with the Fit. - Gas mileage can drop if your thermostat is not properly maintaining coolant temperature. There are a few tell tales of failing thermostat (e.g. interior heat is only luke warm on the highway now). - You might look to buy an OBD port reader or app that reads all kinds of data real time to help identify issues (MAP, MAP, water temp, ST/LT fuel trim, o2 sensors, cat temps, knock retard, etc). We have an old ScanGauge2 that some hyper-milers use but there are many other options today. - If your electric system is heavily corroded the very small battery will not get sufficient spark to the engine, so combustion may be suboptimal. As you are in Canada maybe salt has corroded battery connections, grounds, main power terminals. You can visually inspect and try voltage drop test (bottom of this post can help explain what voltage test is- quick and easy to do just use caution for health & safety). This can also improve starting in cold conditions. https://www.fitfreak.net/forums/2nd-...fit-sport.html |
If I remember right 5th gear in a manual on the Fit runs at higher RPM than 5th gear on the AT. So 70 mph will get lower mileage. Especially with snow tires. How is your mileage at 60 mph? (you could reset the computer for that run, or just look at the bar graph on the dash)
Do you rev the car a lot getting to the highway? Is the route hilly? (you use more gas going up hill than you save coming back down the same hill) |
Originally Posted by GolNat
(Post 1421180)
Originally Posted by Fiting
(Post 1421274)
Originally Posted by julianachos
(Post 1421289)
Originally Posted by Brain Champagne
(Post 1421303)
Do you rev the car a lot getting to the highway? Is the route hilly? (you use more gas going up hill than you save coming back down the same hill) And the route is not excessively hilly. __________________________________ Consensus seems to be winter tires and fuel suck. With the weather we have and the amount of driving I do, all four winter tires are staying on! I'll report back in the summer once better tires and gas are back! I'm also going to compare it to our HRV. |
In my 2011 I regularly get 36-38 mpg in the summer and have been getting 29-32 in the winter (with warming up the car). My hubby works at the local refinery and says it's just the winter gas that makes the difference.
OP - check the speed limit on 401. I believe it is 100 not 110.
I kept track of my mileage for 6-7 years and got 7.8l/100kms. Winter gas will drop mileage. |
Does your fit have a block heater? If so, and the temperature regularly is below 20°F (-6.5°C) consider plugging your car in for the night. Using a wattage meter, and average price/kilowatt of energy where I live, it costs less than a dollar per day to plug it in throughout the night. When you start it in the morning, the coolant will already be somewhat warm and that will help the engine get to it’s optimal operating temperature quicker, therefore making the engine more effienct and increasing MPG. |
If you drive faster you'll arrive quicker. You can use this extra time saved to wash windows, pan handle, or sell drugs/tamales from the back of your fit, thus offsetting the price of fuel.
alternatively you could cut weight by removing the rear seats or tamales. Its uncommon for folks to want to do this, but I've ditched the A/C system in an older car and replaced the compressor with a bypass pulley. Cuts weight and reduces load on the serp. You could also try driving with a less-full gas tank and get gas more frequently to, again, cut weight. Those are the significant free/super cheap ways. You can also read up on tire rack to see (what I assume is generalized or approximate) tire weight next time around. Unsprung weight somethin somethin whatever. I know essentially nothing about it, but hey, maybe dump some toulene in there. Slap on a +10 hp sticker and you're FIT to fly.... apologies for all of this. waiting for the lady to get out of the OBG :popc: there may have been some good info in there though! |
TMI!!
Not the car stuff. I like your rational for arriving quicker. I'm emotionally attached to the A/C though. |
Our 2012 is getting 10L/100 km in town, that’s approx 28 mpg during winter trips. |
Originally Posted by Steve244
(Post 1421975)
If it makes you feel any better, I average 25 with a 50/50 split of city and highway traffic. This engine doesn't like cold weather whatsoever. I will see my daily commute drop a few mpg when it gets down to single digit (F). It doesn't help that I need the heater and no one can drive in snow, so more traffic.
Thanks for the replies folks! I did manage a 30 a few fills ago... Its that darn cold weather. I'll wait for the summer to start seeing better MPG.
Has anyone noticed a difference in cruise control on vs off on the same trip? I want to say I got better mileage yesterday and today because I didn't use CC for my highway trip. |
