Need Help In Replacing Battery 2012 Fit
Old Jan 30, 2019 | 01:10 PM
mharnisch's Avatar
Originally Posted by Black3sr
the battery only 1 1/2 years.
the back thing has a fuse in it.. it then runs to the tender.
At least it should be under free replacement warranty. How long have you had the battery tender wires and fuse connected? If it was installed only recently, it might be the cause of the drain. Easy enough to disconnect or just remove the fuse and see if that helps. Hope it is that easy.
Old Jan 30, 2019 | 11:07 PM
xxryu139xx's Avatar
I have found that the negative post on the my 51r battery was slightly smaller than the oem one. Tightened all the way, it has no give twisting it clockwise counter clockwise. However, it will come off if u pull it up. Had to shim it so its extra tight.
Old Jan 30, 2019 | 11:21 PM
SiXiam's Avatar
I installed the NAPA one on 10/17/2018.
This one:
https://www.napaonline.com/en/p/NBP65151R
So far so good. Remote started good at close to zero degrees today.
Old Jan 31, 2019 | 08:03 AM
mharnisch's Avatar
I heard this is an issue when switching to the 51R. Also heard that you can buy battery terminal shims to remedy this. Haven’t checked on who might carry these yet.
User1
Feb 28, 2018 10:02 AM
tonyrace_41
Apr 4, 2016 11:23 PM
Antpwny
Aug 23, 2013 12:04 AM
FitsGood
Dec 26, 2011 08:04 PM
spreadhead
Nov 20, 2009 09:50 PM
