Generic Floor Mat Option
Old Dec 28, 2009 | 07:46 AM
Ultrawolf's Avatar
For those of you who think there are already too many threads about floor mats - STOP READING! You'll just get all upset.
For those looking for a less expensive option for front floor mats, I found some Sears rubber truck mats that fit pretty good. They cover the floor quite well, go up under the pedals without presenting an edge that could cause a pedal to get stuck, and trap a lot of water and mud. They even have an angled corner that somewhat matches the Fit's floor shape. I chose not to trim mine, but they could be made to fit even better with trimming. There's a silly cutout/window in one corner of each mat but it doesn't seem to be in a spot where a lot of dirt or water drops through. They were only $10 for the pair on sale, but regular price of $20 is still pretty low.
To help keep the drivers side mat from sliding around, I put a sheet of some grippy foam shelf lining under the mat. The very top of the drivers side mat pretty much butts up against a plastic shield where the steering column penetrates the floor/firewall which also helps keep the mat from sliding. Here are some photos:
Old Dec 28, 2009 | 03:58 PM
Shockwave199's Avatar
Not bad, but how does it conform to the 'dead' pedal on the left? Looks like quite a hump because that mat is thick. And that pedal is pretty important for my comfort. I have generic mats that work well- fabric ones.
Dan
Old Dec 28, 2009 | 04:10 PM
Occam's Avatar
I buy cheap carpeted mats, and then trim them. Use a cigarette lighters and slightly melt the fibers at the edge, and they won't unravel. Buy a new set each year... Doesn't matter, they're cheapies.
Old Dec 28, 2009 | 05:01 PM
Ultrawolf's Avatar
Dan
They lie flat on the dead pedal, so you lose the 1/2 inch or so thickness of the mat there. There's space behind the mat just to the right of the dead pedal.
Old Dec 28, 2009 | 06:18 PM
specboy's Avatar
From the pics, it doesn't look like it would work at all for a 5MT. There isn't room to comfortable depress the clutch without possibly scraping but... hey for $20, you could buy another set and see if cutting out the dead pedal area would work. my other concern would be them sliding forward under the gas and brake.
~SB
Old Dec 28, 2009 | 09:38 PM
I use a really good and heavy fiber mat my GF got me a couple of years ago- I think from QVC. They fit fine and don't move around. I really prefer a good fabric mat because it traps and holds the dirt, as opposed to it dumping freely around in a platsic mat well. I was all into a perfect Fit mat when I first got the car- not so anymore. Any mat that's fit well enough will do the job.
What is more of a concern for me is getting my lazy and sometimes heavy booted feet up and over the door sill and squarely on the mat. I HATE whacking or skimming that door sill with my feet. And so, I make a real effort not to do that.
Enjoy your mats. Looks good!
Dan
Old Dec 28, 2009 | 09:42 PM
Btw- I think these are them, or my mats are very much like these.
Trapz-it Set of 2 28"x18" Front Seat Car Mats - QVC.com
I have the light grey ones. They fit fine and REALLY wear well. They never appear dirty, but then when you dump them over they are holding a ton of dirt/sand. Really great mats.
Dan
Old Jun 30, 2010 | 04:07 PM
Alithis's Avatar
Has anyone with a M/T tried this sears mat?
Old Jun 30, 2010 | 04:17 PM
alanchan's Avatar
nice find
Old Feb 16, 2011 | 04:59 PM
splat matt's Avatar
I could not find the sears floor mats suggested by the OP but I did find a nice set at COSTCO for 12.99 (front & rear). Colors: Black, Gray, & Tan
[2010 Fit Sport M/T]
codenamezero
Jan 25, 2012 08:14 PM
mtunofun
Oct 22, 2009 01:05 AM
jamtrino
Mar 22, 2009 05:45 AM
ghostagent
Mar 19, 2008 05:10 PM
Jonniedee
May 18, 2006 09:49 PM
