Dropped Ratchet - Lands perfectly inbetween battery terminals
Old Mar 28, 2019 | 12:23 AM
ChuckDustin's Avatar
Okay,
So I have the worst freaking luck. I was doing some work on my 2011 FIT..next thing I know, accidentally drop my ratchet and it lands wedged RIGHT INBETWEEN the battery terminals. There was a nice spark and then the wrench was literally stuck on there. I was finally able to pry it off with the end of a hammer, and it took quite a bit of force to get it off. (Went flying upon removal) Was on there for about a minute.
Currently have battery reconditioning on the charger right now.
Is there anything I should be concerned about? X.x
Thanks in advance!
Old Mar 28, 2019 | 05:16 AM
Frenzal's Avatar
Not sure if your battery will still be good...
Old Mar 29, 2019 | 10:55 AM
Alco RS-1's Avatar
Instant welding machine. My luck is often the same as yours. I usually disconnect the negative battery cable and wrap a shop towel around the cable end to insulate it from touching anything. I'm with Frenzal, in that your battery may be damaged.
Old Mar 29, 2019 | 02:50 PM
Update:
Tried to recondition battery with my charger. No luck.
Had to get a new battery. Found one from NAPA for 130 bucks. 😑 Expensive mistake on my part. Definitely kept the covers that came with the new battery to prevent this from happening again.
Old Mar 29, 2019 | 08:48 PM
GolNat's Avatar
I caught a ratchet on fire once arcing it across a 28VDC battery bank, lots of fun!!! Sears rebuilt the ratchet for me after the internals melted. Still have the ratchet somewhere.
Glad it didn't cause any further issues.
Old Mar 29, 2019 | 09:11 PM
Lmao, yeah I couldnt believe it. When I first tried to get off with my leather glove, I knew i had FD up. At that point i knew it was a ticking time bomb and this was a BIG ratchet.
I just remember running around the house looking for my hammer because it wasn't in my toolbox the one time I need it.
I also remember my wife asking what the hell I was doing.
"Nothing.. *pant*.. battery.. *pant*.. short circuited."
Finally found the bastard after 1min 30sec of vigorously searching, ran back, and took nearly all my strength to pry it off. Good times.
erichyung
Mar 16, 2026 04:11 PM
Jensen Healy
Dec 6, 2019 02:54 PM
pzriddle
Jan 23, 2015 06:31 PM
Remco
May 4, 2005 11:16 AM
Remco
