Washer Fluid Pump not pumping
Old Jul 28, 2019 | 03:27 PM
uRabbit's Avatar
Do the front and rear use different motors? Neither is pumping liquid. I can't hear or feel anything in the lines when my partner pulls the washer lever.
I think there may even be just water in the tank, which probably destroyed the motor. Don't see any leaks in the reservoir, but it's also not all the way full.
Anything else I should check for before going for a replacement?
Old Jul 29, 2019 | 12:29 PM
Red 05's Avatar
There is only one pump, underneath the reservoir tank with the line for the rear window running along the passenger side of the car along the sill.
Straight water is fine for windshield washer fluid, presuming you don't freeze. Windshield washer fluid usually has a bit of alcohol in it to prevent freezing.
This is from the service manual for testing to see if your pump is bad or not. If it isn't bad and still doesn't work let me know, there's a lot to try but this is sort of the first thing to try. The other being pull fuse 21 under the driver side lower instrument panel (controls washer, 15 amp fuse) and see if that's been tripped.
EDIT: added wheel well removal instructions if needed.
Old Jul 29, 2019 | 02:06 PM
uRabbit's Avatar
Hooo doggy, that'll be a fun one. Okay, I'll have to do this on a weekend.
hogwylde
Jan 21, 2025 09:50 PM
BasicWhite
Apr 27, 2015 01:10 PM
msoulier
Feb 1, 2014 10:59 PM
some_dude
Jan 30, 2011 05:51 AM
bestfit
Feb 17, 2007 07:11 PM
