My 2009 Fit is hard to shift at start up
Old May 27, 2020 | 09:50 AM
walker1200's Avatar
Hello,
I have a 2009 Fit with 158k that doesn't want to shift into gear when I start it up in the morning. I usually run the engine and depress the clutch a few times as it warms up. Then it will eventually go into gear. After that, I'll have no problems. It seems like after it sits for a while, its a bit tough to get into gear. I've owned it for about 3 years and I have not had the fluid changed. Thank you for any information you can provide!
Old May 27, 2020 | 12:09 PM
Red 05's Avatar
Originally Posted by walker1200
Hello,
Should be changing transmission fluid at 36k intervals.
Old May 27, 2020 | 01:03 PM
walker1200's Avatar
Thanks for the reply. Yep, I get that, and I will look into getting that done. Have you had that happen to you, and do you think that will fix the issue I'm experiencing? I have not yet had this specific issue happen in any manual transmission I've owned. Thanks!
Mercfh
Sep 10, 2014 08:44 PM
GinoLicious
Feb 14, 2014 10:31 AM
dutchdog
Oct 29, 2013 02:19 PM
ruknight4ever
Nov 10, 2008 12:56 PM
Vaskar
Jun 11, 2008 08:33 AM
