How can I test fuel pressure.
Old Sep 8, 2023 | 11:31 PM
Kenword's Avatar
I have a 2010 Fit Sport with manual trans. I suspect I may have a minor fuel injector leak and understand that one way to tell if it leaks is to do a fuel pressure test and see how long it takes for the pressure to drop when the engine is shut off. I have a fuel pressure gauge for EFI systems but can't find the test procedure or pressure specs anywhere. Any advice is greatly appreciated.
Old Mar 13, 2024 | 12:43 PM
Kenword's Avatar
Update: Since I posted this I bought a copy of the Honda service manual and found out the only way to check fuel pressure is to install a pressure gauge into the fuel line at a quick-connect fitting near the air filter. Normal pressure is 47-54 psi with the engine running at idle. The manual does not say anything about how long the system should hold this pressure when the engine is stopped. I hope someone finds this information useful.
Old May 17, 2025 | 10:05 AM
Kenword's Avatar
I have received a PM from Elavanis requesting help finding the fitting used to check fuel pressure. I took a few pics and hope they will help.
Here is the engine of my 2010 Fit. The arrow points to the quick-connect fitting where fuel pressure is tested.
Here is a close-up
The piece with the square hole needs to be pulled off to reach the fitting.
Press down on the turquoise colored tab at the left and the fitting will separate.
Hope this helps someone.
Bsmooth
Apr 14, 2023 12:55 PM
Myxalplyx
May 11, 2016 12:29 AM
clanbuster
Mar 18, 2010 02:45 PM
YeeFit
Feb 23, 2009 12:01 AM
prossett
Dec 20, 2007 10:46 AM
