SOUNDS GREAT, but what's the damage?
Old Feb 3, 2011 | 05:33 PM
adashjr's Avatar
This morning I revved up my 2009 Sport NAV, and released it from the icy grasp of 4 inches of snow-ice. As I reversed over the small wall the plow had left behind my car, not even 6 inches high, there was of course some scraping of the underbelly. I shifted into drive and lo and behold!!! I'm now driving a tuner car with a gorgeous deep throaty note. Surely I had removed a section of the exhaust from my vehicle!!! Yet my mechanic saw NOTHING. As I pulled away from the mechanic, the FIT roared again, sounds like a G35. If I ain't crazy, there also seems to be a small loss of power. I checked to see if I left any FIT parts near where I scraped the underbelly and I see nothing. Any thoughts anyone? Remember, I backed out and scraped the underside. This snow -ice we have in Jersey is right now strong enough to hold my 300 lbs without breaking the surface. Hard as rock.
Old Feb 3, 2011 | 09:46 PM
Turbo_Mouse's Avatar
check if there is a hole in the flex pipe.... Listen if it is roaring then there must be something broken or with a hole.. can you possibly post pictures from the underside of your car...
Old Feb 3, 2011 | 10:31 PM
Brain Champagne's Avatar
He may have seen nothing but with a mechanic's stethoscope he should be able to pinpoint where the sound's coming from.
Old Feb 3, 2011 | 10:40 PM
adashjr's Avatar
In defense of my mechanic and friend, I been thinking two scenarios: I explained to him I feared I damaged something, but not that the car's exhaust note had changed; was throaty. It's my fault which leads me to number 2, as far as he knows, thats what my car is supposed to sound like.
Old Dec 8, 2011 | 11:14 PM
TheDilweed's Avatar
i'm just curious if you found your problem? i have an idea but it's not likely lol.
Old Dec 9, 2011 | 05:54 AM
cd4ag's Avatar
You could be leaking from one of the flange sections of the exhaust. Your friend might have been looking for some actual damage when u could have just sheared one of the bolts @ the flange and it's leaking from there. You might not even notice if u were just looking for piping damage.
Otherwise just start the car and put ur hand under while someone revs it u should feel the leak if it's making so much noise.
justdriving
Aug 14, 2021 01:52 PM
SilverEX15
Mar 21, 2019 02:56 PM
Seattle5
Oct 4, 2011 04:51 PM
clicq
Mar 6, 2010 05:18 PM
AintNoStoppinMeNow
Dec 27, 2009 07:31 PM
